Woods Blower keeps snapping grade 5 bolts
   / Woods Blower keeps snapping grade 5 bolts #21
The OP was doing fine with the grade 5 bolts, until he wasn't. Something changed.
It could be the shape of the bolts or quality of the bolts. The holes will also loosen up a bit with age which would add sloppiness and might shear easier.
   / Woods Blower keeps snapping grade 5 bolts #22
Something has changed, snapping bolts at an idle unloaded.
Even chineee grade 2 should be fine unloaded.
Something is wrong some place even though it turns fine by hand.
It could be in the impeller, the gear box, even the chain it's self or the auger.
Until the components are separated it will be looking for the proverbial needle in the haystack,
just not so many pieces.
It could be an issue which shows it's ugly hear at a faster speed then turning by hand achieves.
   / Woods Blower keeps snapping grade 5 bolts #23
Bought a woods blower a couple of years ago for my 50hp Kioti and it works like a dream, but recently it has started snapping the grade 5 shear bolts. I can hand turn the auger and then I will turn on the pto, and it instantly snaps the shear bolt. I was working great the week before, but now it is snapping shear bolts. I figured maybe I needed to have the pto drive shaft straight out from the auger u- joint, and then I turned on the pto and SNAP! I have no idea why it is snapping the grade 5's. I bought some grade 8's but I am hesitant to use them for obvious reasons. Any ideas?
Did you buy them from Tractor Supply Co? Cheap garbage them bolts!
Can you spin the input easily by hand? If you can, do you feel any unevenness when you do?
I’m thinking there may be a bad bearing in the 90-degree gearbox, which is causing
it to bind up when input is applied via the PTO, but not when you turn the impeller, sending the load in from the other side.
It is pretty new, and I haven't picked up anything that would have caused it to bind. When the snow is cleared, it turns very easily.
Don't go to the grade 8 bolts. As suggested, try an alternate brand of grade 5.
Also thinking the "bad bearing/worn bushing" , as suggested by jigs could be the cause.
Obviously - something is binding up when you apply power. Is everything well greased up?
Actually, I haven't greased the u-joints.... maybe I'll try that.
Does the tractor ALSO have a foot clutch.
I know it isn't "needed" to engage PTO on most modern tractors. But if the clutch pedal does indeed disengage the PTO (it does on my Kubota MX)....by pushing the clutch, then engaging the PTO, it allows you to slowly engage the implement
So the foot clutch also engages the pto? Really? Didn't know that.... I may try that. It's worth a try.... it is dumping outside and I need that blower.
I doubt if too many TBNers have a gear tractor with a live PTO anymore. I had a couple in the old days (Deere 670 and 790), and LD1's post exactly describes the process. I'll add one thing...if the tractor has a foot throttle, be prepared to "blip" the RPM when engaging the PTO.
What would bliping the throttle do?
Yup, most of these small tractors anymore are HST. But up until 8-10 years ago....most still had a clutch.
Only recently have they gone away from that so they could put the split brakes on the left side.
Some like it that way. Personally I still prefer the clutch. Cause it still disengages the PTO. Doing alot of brush mowing....that's my first oh $hit instinct is to stop on clutch when something sounds amiss. And it also allows feathering the engagement.
I think the OP said his tractor was a 2002 model. I would think it still has a clutch.
The ONLY implements I use that I DONT feather the clutch to ease the engagement on are things with little inertial load. Like a seed spreader, or PHD.
Didn't even think of using the clutch.... I'll try that.
   / Woods Blower keeps snapping grade 5 bolts #29
It does if you have a live PTO...
"What would bliping the throttle do?"
If you're a younger guy, and haven't had a vehicle with a standard transmission, you may not be familiar...
As the clutch is released, the engine may stall (sudden load on the engine). Blipping the throttle increases the RPM, providing more power and, hopefully preventing a stall.
Same thing applies when engaging a PTO powered implement...the sudden drop in engine RPM can stall the tractor's engine
It's live.... .as I am getting older.... I am starting to forget stuff. I wouldn't think that I would have forgotten to use the clutch.. but I guess anything is possible. The only time I use the pto is in the winter, so it's been 6 months since I have used it. CRS syndrome. Thanks everyone!
Swict 78" Bucket (A57149)
Swict 78" Bucket...
Golf Cart Bed (A57149)
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
2018 CASE TR340 SKID STEER (A52709)
2018 CASE TR340...
1997 Dorsey 45' Aluminum Citrus Trailer (A57148)
1997 Dorsey 45'...
2003 STERLING LT9500 SERIES DAYCAB (A58214)
2003 STERLING...
