Woods Blower keeps snapping grade 5 bolts
   / Woods Blower keeps snapping grade 5 bolts #11
Can you spin the input easily by hand? If you can, do you feel any unevenness when you do?
I’m thinking there may be a bad bearing in the 90-degree gearbox, which is causing
it to bind up when input is applied via the PTO, but not when you turn the impeller, sending the load in from the other side.
   / Woods Blower keeps snapping grade 5 bolts #12
Don't go to the grade 8 bolts. As suggested, try an alternate brand of grade 5.
Also thinking the "bad bearing/worn bushing" , as suggested by jigs could be the cause.
Obviously - something is binding up when you apply power. Is everything well greased up?
   / Woods Blower keeps snapping grade 5 bolts #13
If this thing has sheared several bolts over time the holes that the bolt goes through could be getting flogged out which can lead to the problem that you are having. But could also be a chipped gear in the drive box that is jamming when pressure is applied but may not show up when turning by hand.
   / Woods Blower keeps snapping grade 5 bolts #14
Does the tractor ALSO have a foot clutch.
I know it isn't "needed" to engage PTO on most modern tractors. But if the clutch pedal does indeed disengage the PTO (it does on my Kubota MX)....by pushing the clutch, then engaging the PTO, it allows you to slowly engage the implement
   / Woods Blower keeps snapping grade 5 bolts #16
I doubt if too many TBNers have a gear tractor with a live PTO anymore. I had a couple in the old days (Deere 670 and 790), and LD1's post exactly describes the process. I'll add one thing...if the tractor has a foot throttle, be prepared to "blip" the RPM when engaging the PTO.
   / Woods Blower keeps snapping grade 5 bolts #17
Yup, most of these small tractors anymore are HST. But up until 8-10 years ago....most still had a clutch.
Only recently have they gone away from that so they could put the split brakes on the left side.
Some like it that way. Personally I still prefer the clutch. Cause it still disengages the PTO. Doing alot of brush mowing....that's my first oh $hit instinct is to stop on clutch when something sounds amiss. And it also allows feathering the engagement.
I think the OP said his tractor was a 2002 model. I would think it still has a clutch.
The ONLY implements I use that I DONT feather the clutch to ease the engagement on are things with little inertial load. Like a seed spreader, or PHD.
   / Woods Blower keeps snapping grade 5 bolts #18
A slip clutch ends up being mounted on the gear box side of the trailing implement but if there is little room it could be mounted on the stub shaft of the PTO.
   / Woods Blower keeps snapping grade 5 bolts #19
Are the shear bolts shouldered through the shear area or are there threads at the shear point? If it is threaded, you may want to get longer bolts that have the longer shoulder, then cut off excess threads. Also, most use a locking nut and are just snugged...not over tightened.
1306 (A58374)
1306 (A58374)
2015 EAST MANUFACTURING ALUMINUM STEP DECK (A58214)
2015 EAST...
2015 Peterbilt 367 National Crane NBT55 5-Mast 128ft. 55 Ton Quint Axle Crane Truck (A55973)
2015 Peterbilt 367...
2018 JOHN DEERE 60G EXCAVATOR (A52709)
2018 JOHN DEERE...
2021 CATERPILLAR D3 CRAWLER DOZER (A52709)
2021 CATERPILLAR...
2018 Peterbilt 567 T/A McNeilus 2511 25Yd Rear Loader Garbage Truck (A55973)
2018 Peterbilt 567...
