Woods Blower keeps snapping grade 5 bolts
   / Woods Blower keeps snapping grade 5 bolts #1
KanakaRick
Truckee, CA
KIoti DK50S
Bought a woods blower a couple of years ago for my 50hp Kioti and it works like a dream, but recently it has started snapping the grade 5 shear bolts. I can hand turn the auger and then I will turn on the pto, and it instantly snaps the shear bolt. I was working great the week before, but now it is snapping shear bolts. I figured maybe I needed to have the pto drive shaft straight out from the auger u- joint, and then I turned on the pto and SNAP! I have no idea why it is snapping the grade 5's. I bought some grade 8's but I am hesitant to use them for obvious reasons. Any ideas?
   / Woods Blower keeps snapping grade 5 bolts #3
Pop the auger drive chain off and see if you still snap shear bolts,
could be the impeller.
   / Woods Blower keeps snapping grade 5 bolts #4
The traditional cure for that is to engage the PTO clutch more slowly. But lately some tractor manufacturers have been replacing the PTO clutch with a simple on/off switch. The problem then is how to slow down the engagement.
Is there room to add an adjustable slip clutch between the PTO output and the drive to the blower? That would fix the problem.
I've never used one of those slip clutches myself, but they are common slip on units for PTO shafts & and not expensive. It's good to have one to protect the PTO internal gears anyway.
good luck,
rScotty
   / Woods Blower keeps snapping grade 5 bolts #5
Are you starting the blower at full rpm? If you're easing into it at an idle, it should not be breaking shear bolts. I would not go to grade 8.
nope, just at idle.
I can turn the impeller with my hand, so it doesn't have any rotating issues.
good luck,
rScotty
it's a 2002 Kioti, and i have no idea about slip clutches.
Maybe try a different brand of grade 5's.
That's what I was thinking. The tractor is at idle, and as soon as I turn the button on that turns on the pto, the bolt snaps. A couple of days ago, it worked fine, but now I have no idea. After the bolt has snapped, I can turn the auger with my hand, so there isn't anything in the auger that would prevent it from turning.
   / Woods Blower keeps snapping grade 5 bolts #10
Easiest thing is to try another brand pf Grade 5 bolts.
It's an unfortunate fact that there are counterfeit bolts...lower grade then what's advertised or marked on the head. Very serious problem with Grade 8's, but that isn't limited to the harder grades.
Case 1083 20ft Corn Head (A56436)
Case 1083 20ft...
1661 (A58375)
1661 (A58375)
2012 DOOSAN G25KW GENERATOR (A58214)
2012 DOOSAN G25KW...
2017 Freightliner M2 106 24ft Box Truck (A56858)
2017 Freightliner...
LINDE H80D FORKLIFT (A58216)
LINDE H80D...
JLG SCISSORLIFT (A52705)
JLG SCISSORLIFT...
