Woods BH80X on a 2920
   / Woods BH80X on a 2920 #1
jakell2010
2007 Cub Cadet 5364D
A local Kioti dealer went under and they are selling off the leavings,,,,,,,there's a Kioti BH 80X ,,,which is a WOODS, , now I got a hold of a 2006 spec sheet and on that it says I can get a subframe for a 2710 ( didn't make the the 29),, same tractor , different motor.
Went to the dealer, and they say I can't put an 8' hoe on a 2920,,,,,,
Any body have another opinion
   / Woods BH80X on a 2920 #3
If it's an 8 foot hoe I would be inclinded to think it would be too big for a B2920. The 2x20's come with a 6 1/2' hoe and it is tucked up tight to the rear of the tractor. I don't think the tractor weighs enough to counter the weight of a bigger hoe especially if it may mount a little farther behind the rear wheels.
Just a thought.
Calling woods is probably your best bet unless some one else on here has already done it and can give you some real feedback.
Good Luck ! :)
   / Woods BH80X on a 2920 #4
Probably the Woods 7' 70x would be more likely the largest that would go on a 2920...like BriarPatch said (contact Woods for subframe info) the Kubota 2920 BH65 size is 6 1/2"...in between the Woods 70x and 60x.
I think the Kubota B2710 specs were a little larger frame size than the new 2x20's? I think it has rear tire size of B3200.
   / Woods BH80X on a 2920 #5
As mentioned above, the B2710 is a bigger tractor than your B2920. It was a large frame B-series and is very similar to the B7800/B3200. With that said, really the BH80X is even too big for the larger frame B's, although I know quite a few people use them that way. It would be more suited to an L series.
   / Woods BH80X on a 2920 #6
I'm with the majorty here. The 2710 has a longer wheelbase than your tractor...... subframe for it wouldn't even be close to fitting your tractor. The BH 80x is too big for your tractor. You would need to add weight to the front to keep the wheels on the ground.... literally. I would give some thought to putting the appropriate Kubota hoe on your tractor, since it's a more integrated design and makes for a shorter more compact TLB.
   / Woods BH80X on a 2920 #7
technically, the mounts from the 70x would work on the 80x... however, that hoe is way too big for the tractor.
Beck,,,,I emailed them 3X , no response and they said they'd have to get back to me, but recommended I seek out a dealer
I understand everyone saying that it's too big, I just have the opportunity to get a new one for $4+
   / Woods BH80X on a 2920 #9
Maybe it might be worth it to trade the tractor in on a new one that the 80X will fit on ? :thumbsup: :cool:
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2007 International 7400 Chassis Truck, VIN # 1HTWGAAR87J437650 (A51572)
2007 International...
2020 Peterbilt 520 Truck (A51692)
2020 Peterbilt 520...
2019 Bobcat E45 Mini Excavator (RIDE AND DRIVE) (A50774)
2019 Bobcat E45...
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
2011 Kubota R520S Articulated Wheel Loader (A51691)
2011 Kubota R520S...
