Woods BH80-X Weight?
   / Woods BH80-X Weight? #1
westbrooklawn
Platinum Member
North Carolina
kubota L3400HST
Does anyone know the weight of the Woods BX80-X backhoe? I can't find it anywhere in the Woods literature.
   / Woods BH80-X Weight? #2
Westbrooklawn:
Are you thinking of one of these bad boys for your L3400? I've been eyeing it also. I want to make darn sure that I want to hang on to my L3400 for along time before I take the plunge though.
I don't know the weight but everyone that has a L3400 and the BH80-X here seems quite happy with it.
Get the subframe if you do get it though.
canoetrpr -
I already bought and installed one about a month ago, with subframe... I love it! The reason I was wondering about the weight is that the backhoe seems to be a good ballast weight for using the WR Long bolt on bucket grapple that I installed, so I want to make a ballast that is about the same weight for when I have the backhoe off. I have a nice 30 gallon plastic drum that I was going to fill with concrete, but it will only give me about 600 - 650 lbs., and I'm not sure if that will be enough... I think I will look for a 55 gal. drum instead.
Mike -
Thanks for the answer! If I use a 55 gal drum I should be able to put a few cavities for tools, chain, etc. and still get around 900 lbs... that should be just about right.
   / Woods BH80-X Weight? #5
mrutkaus said:
850lb pretty sure; the 70X weighs only 50lbs less.
Mike
I'll bet that is w/o the bucket. I would guess its a little over 1000lbs with bucket. I downloaded the manual and even it didn't include the weight. Most competing hoes of that size weigh about 1000+lbs with a standard 16-18" bucket. Does your loader manual give a recommended ballast? Some do. Having the grapple won't increase the load carried, though it might increase the chance of an off-centered load.
   / Woods BH80-X Weight? #6
I'm not sure of the weight but would estimate closer to 1000lb than 850. I have the BH90X on my Kioti DK40se. It is heavy enough that the front end feels much lighter than with just a mower. I'll end up adding some front weight in addition to the FEL just to make it balance better. The Kioti is heavier I think than the 3400 so I would advise thinking about the weight balance issue issue with the 80X too.
By the way, I love the BH. I'm thinking of getting a ripper tooth fabricated to make smaller stump removal faster and less destructive.
   / Woods BH80-X Weight? #7
That's a nice new DK40 you have there Island. Did you keep the CK20 too?
   / Woods BH80-X Weight? #8
Wish I could have but I needed to trade it in on the new one. It was a great tractor though.
   / Woods BH80-X Weight? #10
I know 830lbs is real good on the back of my L2800 for ballast.
2018 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A53472)
80in HD Tooth...
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
2007 Volvo VNL Truck Tractor (A53472)
2007 Volvo VNL...
