Woods BH7500 Leaking Oil When Tractor Running, Without Moving any SCVs
   / Woods BH7500 Leaking Oil When Tractor Running, Without Moving any SCVs #1
gckshea
SE Tennessee
2018 LS XR4140
Hi All, I recently picked up a Woods BH7500 3 point hoe. It had only one previous owner, who left it outside it's whole life, and not used in the past 5-6 years. I know some of the hoses are more than sun checked and weathered, so replacements are on the list. No cylinders leak at all - yay!
My issue is I think I have multiple hose leaks in hoses within the boom, at the hinge point of the boom and the swing bushing...but not 100% sure, since oil runs downhill at all times. This is where the leak seems to come from.
I should point out no leaks occur when the backhoe is disconnected from tractor hydraulics. It immediately begins to leak as soon as the engine is started, before moving any cylinder controls.
My question: which hoses should I be looking for if the leak(s) occurs without opening an SCV (operating any control levers) and the tractor is running? I can't see any wetness, spray, or drips coming from the control block up top, and the supply and return lines to the tractor appear intact and dry - they are the newest of any hoses. ❓❓:unsure:
   / Woods BH7500 Leaking Oil When Tractor Running, Without Moving any SCVs #2
If leaking when not in use or SCV not being operated I would first suspect hoses and fittings on the end of the cylinder that has load induced pressure. I.e. if load is trying to extend the cylinder then load induced pressure is on the rod end port.
yes seeing inside the boom can be challenge.
2008 STOUGHTON TRAILER STOUGHTON TRAILER (A55745)
2008 STOUGHTON...
Tires (A50322)
Tires (A50322)
UNUSED 70PCS White Metal Roof Panels (A53117)
UNUSED 70PCS White...
2000 GMC C7500 SINGLE AXLE VOCATIONAL TRUCK (A56129)
2000 GMC C7500...
2017 RAM 5500 Bucket Truck - Cummins Diesel - Automatic - 4X4 - Terex TLM40 Boom (A55302)
2017 RAM 5500...
