Woods Backhoe hydraulic hose question
   / Woods Backhoe hydraulic hose question #1
Jeff Lary
Hartland Maine
Kubota L2950
Hi I know it aint large equipment,.... but it is what I am having an issue with right now IMG_1171.JPG IMG_1172.JPG IMG_1175.JPG . Today I was digging out a an Elm stump and blew a hydraulic hose off of the crimp on coupler . The hoe and tractor are in my back field with the dipper in the hole so there is no getting the tractor home to work on it whatever I do will be in the field.
This is my question , I think the hose was a crimped into coupler fitting type of hose set up. But I need to know if they make a repair coupler that I can connect to the hose out in the field ? The hose is long enough to be reused as it only " blew out of the fitting" so maybe 1/4 inch of hose ruined. I will take my generator to the field and use a die grinder or Dremel to re-cut the hose for a fresh good end. The hose travels from the valve bank ( where it separated from ) down into the near end of the boom and inside of it till it gets to the curl cylinder about 7 feet away. Getting it out of the inside of the boom will not be an option right now. I would have to disconnect all the other hoses from the valve body and then remove the boom from the rest of the hoe unit so you could attempt to pull the hoses out through the boom. Big big job. So to recap do they make a coupler that I can reinstall on the end of my hose myself with out taking the hose to the repair shop?
Jeff Lary, 30 minutes ago Edit Delete Report
#1 Reply
Jeff Lary
Thanks I will write that down !
Ok so I went to the hydraulic repair shop today and got a little more information in case anyone is following this. I asked "Parker Hose and Fitting" in Bangor about a field repair coupling and they do not stock the 5/16 I needed. So they are on order and will be here in a couple of days.
Now this is what I found out next about the field repairable reusable coupling. I asked if these were indeed a temporary fix as I had heard, he said "God no the north Maine Woods would be at a stand still if not for them things" He told me that most every company up north ( ie ) Wood Harvesting Companies have some in all their equipment. He told me that all the big companies have service trucks and they all carry them. He said that installed correctly they are as good and any other coupling. So I ordered 5 sets just in case I need another field fix. I hope this is of use to someone in need of fixing their own hose someday ;)
RV Hitch (A50121)
RV Hitch (A50121)
2009 Yale Veracitor 135VX 12,150lbs Straight Mast Forklift (A50322)
2009 Yale...
New Valley Pioneer SCL850 Mini Skidloader (A50774)
New Valley Pioneer...
2000 Genie S-60 60ft Telescoping Boom Lift (A50322)
2000 Genie S-60...
2015 Nissan Frontier SV 4x4 Pickup Truck (A50323)
2015 Nissan...
RoGator RG1100C (A52748)
RoGator RG1100C...
