Backhoe Woods Backhoe BH9000 lifting capacity
   / Woods Backhoe BH9000 lifting capacity #1
Komrade
Western Morgan County, WV
Kubota L3430 HST
We would like to use the backhoe to occasionally lift a portion of the porch that is to be built over a stream during floods (to ease access to the culvert for cleaning).
Wanted to know what the lifting capacity is.
Thanks.
   / Woods Backhoe BH9000 lifting capacity #2
Looks to be about 1200 lbs.
   / Woods Backhoe BH9000 lifting capacity #3
Lift capacity dramatically decreases the further the boom is extended.
   / Woods Backhoe BH9000 lifting capacity #4
are you lifting portion of the bridge out of the way. so any limbs and like will go down stream? and then just letting bridge back down?
   / Woods Backhoe BH9000 lifting capacity #5
My owner's manual says nothing about lift capacity, and I would not expect it to as it also says the backhoe is not made for lifting. Plus the distance the load is from the base of the boom will make a huge difference.
The only reference I see to 1200 lbs is the minimum lift capacity of a skid-steer if that is what you are mounting it to.
Thanks for your responses, we decided to build it in sections so that we could lift a portion of it with forks so that we could clean the culvert underneath
   / Woods Backhoe BH9000 lifting capacity #7
Sounds like you are making the smart & safe move.
2024 Xpro Mini Dirt Bike (A50324)
2024 Xpro Mini...
Year: 2008 Make: Chevrolet Model: Suburban Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 219,... (A51694)
Year: 2008 Make...
CATERPILLAR IT28G (A52472)
CATERPILLAR IT28G...
2012 JACK COUNTY 130BBL VACUUM TRAILER (A52472)
2012 JACK COUNTY...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A52748)
Kubota 24in Quick...
