Backhoe Woods Backhoe BH9000 lifting capacity
   / Woods Backhoe BH9000 lifting capacity #1
Komrade
Western Morgan County, WV
Kubota L3430 HST
We would like to use the backhoe to occasionally lift a portion of the porch that is to be built over a stream during floods (to ease access to the culvert for cleaning).
Wanted to know what the lifting capacity is.
Thanks.
   / Woods Backhoe BH9000 lifting capacity #2
Looks to be about 1200 lbs.
   / Woods Backhoe BH9000 lifting capacity #3
Lift capacity dramatically decreases the further the boom is extended.
   / Woods Backhoe BH9000 lifting capacity #4
are you lifting portion of the bridge out of the way. so any limbs and like will go down stream? and then just letting bridge back down?
   / Woods Backhoe BH9000 lifting capacity #5
My owner's manual says nothing about lift capacity, and I would not expect it to as it also says the backhoe is not made for lifting. Plus the distance the load is from the base of the boom will make a huge difference.
The only reference I see to 1200 lbs is the minimum lift capacity of a skid-steer if that is what you are mounting it to.
Thanks for your responses, we decided to build it in sections so that we could lift a portion of it with forks so that we could clean the culvert underneath
   / Woods Backhoe BH9000 lifting capacity #7
Sounds like you are making the smart & safe move.
2015 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2015 Ford F-250...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
2008 Volkswagen Eos Convertible (A50324)
2008 Volkswagen...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A50323)
2007 Western Star...
2017 Rogator RG1300B Dry Fertilizer Applicator (A52748)
2017 Rogator...
2018 MDB LV600 GREEN CLIMBER SLOPE MOWER (A51406)
2018 MDB LV600...
