Rotary Cutter Woods 720 brushbull on a Kubota3540 GST?
   / Woods 720 brushbull on a Kubota3540 GST? #1
bilrus61
Platinum Member
kubota 4200
I'm wondering if it will handle it as in lift it. The Kubota is a GL 3540 with loader and unloaded industrial tires. Gear transmission. 29.5 PTO hp. 2650 lbs of lift 24 inches behind the pins. Woods 720 BB cutter is 6 feet and 1200 pounds. Woods recommends 30 HP as minimum.
Mowing will be trimming around trees/edges and backing into rose bushes. I want the heavier duty cutter as it will hit some limbs that are down and around. I will mow with the loader and bucket on the tractor since we have lots of little sink holes and I have to have the loader to lift the front end out of the hole when it sinks into one. Tractor is 4wd.
I'm thinking I'll be ok on the power but wonder about the hitch lifting that longer heavy cutter. If it was just mowing grass I would sure get the 72 lighter model but don't want to have to fret every time I run over a big multiflora rose bush. I could also run simi mount and leave off the toplink if it won't lift it but would like it to ride 3 pt. Land is gentle rolling and very well known, as in no surprises as I've mowed every inch of it before. Any advice will be appreciated.
   / Woods 720 brushbull on a Kubota3540 GST? #2
I think the BB60 or BB600 would be a better choice. Either will handle multiflora rose bushes with ease. Remember it also has a slip clutch. I would be more worried about 6' with 30 PTO HP plus in the 720 that's a lot of weight for your tractor. It might be the tail wagging the dog. You will notice a difference with it spinning too.
If you are dead set on getting a 6' cutter, I would get a BB72. The only way I would get a BB720 is if a larger tractor is planned in the NEAR future.
If you plan to run it semi-mounted, get the two tail wheel option
(1) 275 Gallons of Aluminum Brightener (A51573)
(1) 275 Gallons of...
New/Unused 10ft Workbench with 30 Drawers (A51573)
New/Unused 10ft...
Chain Link Fence (A51573)
Chain Link Fence...
2025 25ft. 800Amp Extra HD Booster Cables (A51692)
2025 25ft. 800Amp...
2024 Sky Jack SJ45 AJT Man Lift (A51573)
2024 Sky Jack SJ45...
2016 JOHN DEERE 624K WHEEL LOADER (A51246)
2016 JOHN DEERE...
