Woodmaxx Snowblower Shear Bolts?
   / Woodmaxx Snowblower Shear Bolts? #131
I just adjusted the top link by lower it to the bottom holes and it now looks a little more level in the raised position. I should be able to try it Saturday cause our next round of snow is suppose to be Friday evening.
   / Woodmaxx Snowblower Shear Bolts? #132
Install you're draft arms in the bottom holes of the blower as well and then put the blower on the ground and adjust the top link to level it. It's all in the pivot point locations.. The blower in the raised position should look a bit tipped towards the ground, and level out by the time it hits the ground.
   / Woodmaxx Snowblower Shear Bolts? #133
THIS!
You MUST drop your lower link arms down into the BOTTOM holes in the blower brackets. Since you've already moved your top link down, moving the link arms to the bottom holes should put you right.
   / Woodmaxx Snowblower Shear Bolts? #134
As best I can tell from your pictures I agree with the others, move the lift arms to the lower holes in the blower so the upper link and lift arms are as close to parallel as the combination of holes will allow.
Ideally the blower should remain level through it's full range of motion, from on the ground to fully raised.
   / Woodmaxx Snowblower Shear Bolts? #135
If I lift mine all the way up and it doesn't lilt towards the ground just a bit, when I'm blowing on a little uneven ground it will skip a bit that's why I set the top link to angle downward a bit when the blower is lifted all the way up..
   / Woodmaxx Snowblower Shear Bolts? #136
Do whatever works for you but do it with the understanding that the blower input shaft and tractor output shaft aren't aligned with each other when you have the blower raised. In the raised position you usually aren't blowing snow so a small amount of misalignment probably won't hurt anything.
   / Woodmaxx Snowblower Shear Bolts? #137
They actually are aligned, it differs on different tractors depending on the size of the tractor. It's not a one size fits all, most blowers are close to the same overall height, add a tractor with a lot of height and you have more angle to deal with..
   / Woodmaxx Snowblower Shear Bolts? #138
Maybe I misunderstood what you were saying. I made the assumption, my mistake, that you were saying the blower is level when in the lowered position but tipped back when in the raised position. If that were the case the PTO shafts would be at the same angle to each other (aligned) when in the lowered position but not at the same angle to each other (aligned) in the raised position.
The height of the tractor PTO and the blower input shaft make no difference in the angle of the PTO shafts but does make a difference in the angle of the driveline. Any of my discussion has been in reference to the angle of the PTO shafts to each other, not the angle of the driveline.
I'v never had a gift for words so I am probably creating some confusion.
   / Woodmaxx Snowblower Shear Bolts? #139
The steeper the angle on the driveshaft, the faster it will wear out U-joints, but it should work within reason.
If the PTO output shaft on the tractor & input shaft on the impliment aren't square to each other (output shaft is level, but input shaft is pointing up 15 degrees) things end poorly.
Drive shaft velocity - YouTube shows these issues really well.
   / Woodmaxx Snowblower Shear Bolts? #140
If a picture is worth a thousand words a video must be worth a million words, excellent video. It shows what I have been trying to say but doing a poor job of it.
Thanks.
UNUSEDX-STAR 72" QUICK ATTACH GRAVEL LEVELER (A51247)
UNUSEDX-STAR 72"...
2016 Ford Escape SUV (A51694)
2016 Ford Escape...
2004 GMC Envoy SUV (A51694)
2004 GMC Envoy SUV...
2018 VOLVO VNL DAY CAB (A52576)
2018 VOLVO VNL DAY...
HYDRAULIC PTOS (A53843)
HYDRAULIC PTOS...
