Woodmaxx 8600 back hoe on a tmy 494c tractor
   / Woodmaxx 8600 back hoe on a tmy 494c tractor #1
mblancas
Tym C494
How do I turn off the draft control do I put the lever on 1 or 10 to make it not work when the Back hoe is on the tractor
The arm keep going up and it puts the hoe in a bind and I fave to cut the pin to get it off.
Thanks for the help
   / Woodmaxx 8600 back hoe on a tmy 494c tractor #2
Usually there is a mechanical lock for the top link bracket that deactivates the draft control entirely. Have you checked into that?
I have looked through the manual and they don't even have anything on the draft controls. The knob in front of yhe seat fir the lift speed shows a off if you turn it all the way past slow not sure if that is it.
   / Woodmaxx 8600 back hoe on a tmy 494c tractor #4
No. I'm talking about the top link bracket on the tractor side, where the top link goes. There is usually a mechanical lock there that locks the draft control regardless of the lever position.
Sometimes it's a bracket that flips, other times it's a pin that slides through. I think TYM uses a pin though.
2023 John Deere HD40F Draper Head (A53342)
2023 John Deere...
2013 PETERBILT 388 MID-ROOF SLEEPER (A52472)
2013 PETERBILT 388...
2004 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A52577)
2004 FREIGHTLINER...
New Wolverine Push Blade (A53002)
New Wolverine Push...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
