Woodmaxx 8600 back hoe on a tmy 494c tractor
   / Woodmaxx 8600 back hoe on a tmy 494c tractor #1
mblancas
Tym C494
How do I turn off the draft control do I put the lever on 1 or 10 to make it not work when the Back hoe is on the tractor
The arm keep going up and it puts the hoe in a bind and I fave to cut the pin to get it off.
Thanks for the help
   / Woodmaxx 8600 back hoe on a tmy 494c tractor #2
Usually there is a mechanical lock for the top link bracket that deactivates the draft control entirely. Have you checked into that?
I have looked through the manual and they don't even have anything on the draft controls. The knob in front of yhe seat fir the lift speed shows a off if you turn it all the way past slow not sure if that is it.
   / Woodmaxx 8600 back hoe on a tmy 494c tractor #4
No. I'm talking about the top link bracket on the tractor side, where the top link goes. There is usually a mechanical lock there that locks the draft control regardless of the lever position.
Sometimes it's a bracket that flips, other times it's a pin that slides through. I think TYM uses a pin though.
2011 PETERBILT 348 (A52472)
2011 PETERBILT 348...
2018 Lexus IS300 Sedan (A51694)
2018 Lexus IS300...
2003 Mercedes-Benz SLK Coupe (A50324)
2003 Mercedes-Benz...
2005 Chevrolet 3500 (A50120)
2005 Chevrolet...
Pickup Truck Bed (A51691)
Pickup Truck Bed...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
