woodmax fm-78 on a 27hp pto on hilly uneven ground
   / woodmax fm-78 on a 27hp pto on hilly uneven ground #1
TC33D Abe
Southeastern Ohio
TC33D
Anybody have any experience with this flail, 33hp/27pto, wondering if this would be too much on hilly uneven ground.
   / woodmax fm-78 on a 27hp pto on hilly uneven ground #2
Need more detail about tractor. 2wd or 4wd? Gear or HST? R1, R4, or Turf tires? Loader, weights, fluid in tires? HP shouldn't be a problem as long as you watch your ground speed vs brush/ grass height.
I have a 1300lb JD390 behind a 70hp AGCO Allis 5670 4wd with no issue. Also have a 700lb JD25A behind a JD4300 4wd HST with no issues on our TN hill farm 200' hill on 48 acres. All our tractors are on R1 Ag tires that are fluid filled with Rimgard. Keep the loader on the JD4300, but take it off the 5670. There are a few ravines that we need to be careful around, but that's true regardless of what is behind the tractor. I need to widen the track of the 5670 to be more comfortable on the side hill above our pond, but for now we just cut this area with the JD4300. I do the majority of the mowing with the AA5670 and usually cut 4' grass/brambles in M2 (3.2 mph). But if higher or thick Johnson grass i drop to M1 or L4. I mainly watch the output of the cut and slow when i start seeing stalks.
Its 4wd HST,loaded tires with fel NH TC33D
Its comparable with JD4300, maybe 1 more hp.
   / woodmax fm-78 on a 27hp pto on hilly uneven ground #5
IIRC, the JD25A is a little wider than the Woodmaxx 78. I actually was considering the Woodmaxx, but found the 25A locally for $700.
im also wondering if the 1ft offset would cut evenly on uneven land
looks like Woodmax raised prices,guess that changes things.
   / woodmax fm-78 on a 27hp pto on hilly uneven ground #8
If you are patient you can find a used JD25A on tractor house/iron planet/auction time pretty regularly and they offer shipping as well. The 25A has standard JD parts and you can purchase the knives from flail master and clean cutter and it is easy to operate and maintain.
As to mowing the 7 foot rear roller is going to always follow the ground contour so no worries there.
will 27hp pto handle a jd 25a?
   / woodmax fm-78 on a 27hp pto on hilly uneven ground #10
Works great behind my JD4300 HST which is rated at 25.5 PTO HP
2002 International 4300 Cab and Chassis Truck, VIN # 1HTMMAAP02H548742 (A51572)
2002 International...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2005 Ford F650 SVI Crew Cab Hazmat Truck (A52377)
2005 Ford F650 SVI...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
New/Unused CFG Industrial MH12RX Mini Excavator (A51573)
New/Unused CFG...
2003 Polaris Sportsman 700 Twin (A51573)
2003 Polaris...
