Woodland Mills WC-68 wood chipper delivered today!
   / Woodland Mills WC-68 wood chipper delivered today! #1
Underdog57
W Michigan
LS R4041H
Got my Woodland Mills WC-68 chipper delivered today! :) Ordered it online Sunday (1/24/21) delivered to Michigan on Friday (1/29/21). Great service, will put it together tomorrow.
   / Woodland Mills WC-68 wood chipper delivered today! #2
Have had our WC46 a couple weeks now. Really love it. It conserves MY energy in not having to lift stuff so high and to stand there until it slowly chips through. You really have to poke short stuff into the bottom of that roller though. Otherwise, they tend to bounce up and not feed. Chipping on a downhill slope caused a couple minor problems: 1) oil ran out of the cap; 2) the control bar tended to more easily go into neutral. Syphoned a half gallon of oil out (down to 4 gallons; no more can be syphoned out) to save some of the oil. Turned the control arm adjustment an half turn tighter. (located underneath either under a black or red cap pointing towards the tractor underneath the hydraulics. You unscrew the plastic, loosen a 22mm lock nut and turn a 6 mm allen screw clockwise to tighten things up).
Stuff put into the chute tends to go to the right side of the chute. Best to put stuff in from the left side of the chute to better avoid any stuff from rotating into you. I set the hydraulic feed at mid point. Fast enough for me and seems to work well on the JD 2025R. It just sits there loafing at 2700 rpm.
My old MacKissic TPH-122 is now happily running on a 3 series JD.
Our WC46 was ordered on a Friday and delivered to Va on a Wed. Got a $100 military vet discount, too.
Depending on the weight of your tractor, but the most thing to note is the weight of that thing off the 3ph. Yours will be even heavier than the 550 # WC46. The WC68 is 710 #. Don't go over any tree roots when going even slightly sideways on a slope. Could slip down the root and cause it to tip when it hits dirt again. Try to find a flatter area to turn it to take it back uphill.
Ralph
Ralph
Thanks for the advice Ralph, I guess maybe I should put 4 gallons of hydro fluid in it and check the levels.
   / Woodland Mills WC-68 wood chipper delivered today! #4
I would only put 4 gallons in. It will be just below the inlet 田ylinder? The full capacity is only needed on extremely hot days to aid cooling.
   / Woodland Mills WC-68 wood chipper delivered today! #5
You will not be able to see the level due to the inlet 田ylinder? The 4.5 gallons is appareently only needed for cooling on extremely hot days.
   / Woodland Mills WC-68 wood chipper delivered today! #6
I ordered a WC88 on Tue and it was delivered yesterday. Put it together this morning. Have not mounted it on the tractor yet, snow expected on Tue so blower is staying on for now. Impressed with how easily everything went together.
I put my WC68 together today, just have to put oil in it tomorrow. Unit was packaged very well, everything was wrapped in lots of plastic and securely strapped down. Was very pleased at the build quality, everything seems heavy duty.
It fit my Quick Hitch perfectly just like my 2 Land Pride and 1 EA implements.
I really like the way the feed chute comes straight off the back and folds up to a 4' x 3' foot print (space is at a premium in my garage!) I'm going to put some good casters on the bottom of the shipping pallet and be able to store it in the corner. Hopefully it works as expected.
Neighbor cut 6 or 7 tree's down today so I have some work for it! :)
   / Woodland Mills WC-68 wood chipper delivered today! #9
I also got my WC68 in yesterday and today was assembly day. Hit one snag. Perhaps someone here can steer me in the right direction.
I am to the point of mounting the discharge chute. The directions say it should be installed with the rotator release pin on the tractor side. When I do that the 4 bolt holes don't line up. Close but no cigar. I tried getting even 1 in to see if that would help but I can't get a single bolt in. If I rotate it 180 degrees so the release pin is away from the tractor the holes line up fine :(
Suggestions? Does it really make a difference since you can rotate the chute?
Mine went on like the book says, (release pin towards tractor). As long as you can access it from the other side and it doesn't interfere with anything it shouldn't be a problem. I noticed the 2 bolts on the tractor side were 16 mm long and the 2 on the other side were14 mm long, (thought that was odd)
2011 WABASH 53x102 DRY VAN (A53426)
2011 WABASH 53x102...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
UNUSED FUTURE J5T TON 36" HYD THUMB CLAMP (A51248)
UNUSED FUTURE J5T...
2001 CATERPILLAR IT28G (A52472)
2001 CATERPILLAR...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A51694)
2009 Skeeter SL190...
