wooden clutch pedal spacer
   / wooden clutch pedal spacer #1
zeljko zoricic
hi and marry christmas to all. does anybody know the dims. of the wooden spacer for the clutch pedal on a 1715 model? since i got the tractor used it didn't come with the block & string, i would like to fab. one. thanks and god bless america zeljko zoricic
   / wooden clutch pedal spacer #2
I am not familiar with your tractor. Hopefully someone here on TBN will be able to assist you in regards to your inquiry. It is not my intention to appear too inquisitive, but are you from Bosnia or a neighboring Country?
   / wooden clutch pedal spacer #4
I know of the block you describe I dont think it held the pedal down all the way
just down enough to keep the clutch disk from freezing in the flywheel and pressure plate. I personally did not use it and it got ripped off.I would say push the clutch down and you can fee when it disengages and then measur ethe block from there..
   / wooden clutch pedal spacer #5
I have the one that came with my 1920. I could give you those dimensions if you want.
let me know
   / wooden clutch pedal spacer #6
Zeljko,
There is nothing special about the wood block and it's dimension. Any scrap piece wood block about 3 to 4 cm in thickness will do the job. I'm using a piece of 2"x4" dimensional lumber that is used in U.S for house framing unlike Europe.
Merry Christmas to you as well:)
JC,
   / wooden clutch pedal spacer #8
I use a block that is 1 3/8" X 1 3/8" (35mm X 35mm) on my 1715 and it works fine. I looked in the operators manual and was not able to find any mention of a string, I just remove mine and carry it in a small box that I have mounted to the rear fender of the tractor.
   / wooden clutch pedal spacer #9
What is this block spacer used for. I've got a NH TC30 - shibara motor and other similar parts I think. What is the concern?
   / wooden clutch pedal spacer #10
During tractor storage, specially for a long period the moisture developed due to condensation on the surface of pressure plate or flywheel might help to accelerate some minimal surface rusting. This rusting will go away real quickly as the tractor starts and along a few clutching / changing gear or direction.
On occasions pressure of the mating part caused by pressure plate and combination explained above tends to fuse (stick) the pieces together where clutching does not disengage clutch/transmission. blocking the clutch pedal helps to alleviate the problem. Blocking separates component a bit.
JC,
2016 Ranger 570 EFI (A52384)
2016 Ranger 570...
2014 JCB 930 (A50123)
Flatbed Service Truck Body w/ Cargo Boxes and Gooseneck Hitch (A51692)
Flatbed Service...
JOHN DEERE 5075E LOT NUMBER 30 (A53084)
JOHN DEERE 5075E...
2017 Mack CHU613 Day Cab Truck Tractor (A53117)
2017 Mack CHU613...
