Woodchipper or new car?
   / Woodchipper or new car? #1
Glowplug
3rd Planet from the Sun
Kubota M7040HD
I have numerous mountains of brush all over my property. I also have many trees I plan to remove. I read on this forum about the Valby PTO driven wood chippers. I checked it out. It is extremely impressive. I would really love to have one of these. Of course, the tractor that I am going to get is rather large. So I was looking at the higher end models. The top-end CH 260 is the model that I would love to have. I e-mailed the company. It costs $9,970.00!! :eek:
It looks like a fine piece of equipment and I'm sure it's worth it. But I don't know if I can afford to own one. I may have to look into renting. Has anyone ever heard of any place renting these machines?
   / Woodchipper or new car? #2
You don't need to buy the biggest version which is probably designed/built for professional use. You can get a very fine PTO chipper for half that price and a decent Chinese version for under 1500.
   / Woodchipper or new car? #3
You might also look at Bearcat, salsco, and vermeer. They all make largeish pto chippers. If I remember, all are american made.
   / Woodchipper or new car? #4
How about looking for a used, stand alone, tow behind, professional chipper like you see towed behind the power line cleaner's trucks? I would not pay 10k$ for a huge chipper that doesn't even have an engine.
   / Woodchipper or new car? #5
I picked up an early '60's Fitchburg w/ I6 Ford gas for under $3K. Nice to have the tractor w/ brush forks free to break the piles up, etc.
   / Woodchipper or new car? #6
If you have some time, know exactly what you're needs are, and watch Ebay carefully, good used ones can be found. I bought my 6" hydr feed Morbark from an old dairy farmer in Wisconsin for $3000. It's very similar to the Valbys, but even heavier. I think I got an awesome deal. It had a max of a few hundred hours on it and works and looks like new. Look for the smaller Vermeers, but be careful of ones that are sold after being rental units; some can be beat up bad. Even so, the machines are very simple and rugged, and even one in rough shape can be rebuilt relatively inexpensively. Most on E-bay are powered units, but a few PTO-drives occasionally come up. Just be patient.
   / Woodchipper or new car? #7
I cleared my place the same way - mountains of brush too big for the brush hog.
Getting the biggest strongest nastiest chipper eliminates prep work trimming branches before going in the chute.
I bought a 16" drum type 1960's Ford V8 powered unit out of a junk yard for $800. New wiring and runs like a champ. It has no safety features to speak of - new machines are hydraulic with E-stops. It eats about 100 fpm about 10x faster than newer hydraulic feed units.
Rent centers have back yard ~ 20 hp units, not seen any monsters for rent. Might try calling an Arborist or Landscaper to rent his over a weekend. Liability might get a little tricky but worth a try.
A PTO powered unit may cause the tractor to wear the debris depending on wind variations.
Be sure to add action pix's of your work.
   / Woodchipper or new car? #8
I have a Patu C170 chipper with hydraulic feed rolls. To me it would be nice to have a separate chipper not attached to my tractor at times. I also have a Fransgaurd 4000 logging winch. I use the pallet forks to move what I can. I will use the winch to drag all my trees into one spot, then grab my Normand 1920 dump trailer and park it where I will be chipping. When I start I just aim all my chips into the trailer. The chipper is just awesome. The rolls are adjustable on the front so you can slow the speed down as needed. When I bought my tractor it came with 11 attachments. I probably wouldn't of bought a chipper as a implement because I don't use it that often, but it does come in handy when needed. Plus I think I have gained more "friends" since I bought my tractor.
(1) 12ft Tarter Livestock Panel (A48837)
(1) 12ft Tarter...
KUBOTA L35 TRACTOR (A50458)
KUBOTA L35 TRACTOR...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A50397)
Kubota 24in Quick...
377932 (A48837)
377932 (A48837)
275 Gallon Liquid Storage IBC Tote (A49346)
275 Gallon Liquid...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
