Wood you cut this?
   / Wood you cut this? #1
woodmills1
hudson, NH
kioti LK3054
I know that many of you don't get into the sawmill thing, but here is a cut off from a bone of a log that was still to heavy for my loader. The question is do you think the 9 foot cut off is worth sawing on the mill?
Here is a second shot that shows the 19, 17, 16, 15, 14 and smaller boards I got from this bone and two other logs that were just as bad.
   / Wood you cut this? #3
If you need the wood looks like you saved a good ammount of money!
I make wood products here is a shot of some othe boney stuff I cut and then the 4x4 product I get from it.
nice 4x4 pine from just plain junky logs.
   / Wood you cut this? #6
Looks better than the junk at HD! /forums/images/graemlins/grin.gif
Real nice.
   / Wood you cut this? #7
Wodmills1:
Long time no post from you. Sure nice to see lumber from what is considered non mill trees.
I cut a little but only have a chain saw. Then have to use band saw and planer/ jointer to get it to flat and square. A long process. I'm thinking of making a guide for the chain saw so that I can make square pieces that will then fit through my bandsaw. Most of the stuff I work with wouldn't fit a mill. When I get organized, Maybe this winter, I'll get enough cut and get someone with a mill in. They charge around $45.00 an hour around here. More if they hit metal.
Egon
   / Wood you cut this? #8
Egon-Never used one, but they make chainsaw sawmills. You attach a chainsaw to a frame and use it to cut logs into boards. Do a search on the internet for chainsaw sawmills. Might be just what you need for small time cutting.
   / Wood you cut this? #9
ani't no such thing as junk logs, as anybody that has tried to buy lumber latley can attest to /forums/images/graemlins/grin.gif
   / Wood you cut this? #10
BB:
I've looked at the chainsaw mills. What I'm thinking about is more like an edger that will be able to square up a log. My saw isn't large enough [ Husky 362 ] to properly mill logs.
Egon
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
PREDATOR VACUUM PUMP (A53843)
PREDATOR VACUUM...
2006 INTERNATIONAL 7400 6X4 DUMP TRUCK (A52706)
2006 INTERNATIONAL...
2020 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A52377)
2020 Caterpillar...
2018 DRAGON ESP 130BBL VACUUM TRAILER (A53843)
2018 DRAGON ESP...
