MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 67,345
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
It specifically states in the manual to operate it with chimney connector temps of 250-450. I'm getting that with stove top temps of 300-500. I'm not running it as supplemental heat. Its my main heat. The furnace only comes on if the house gets below 65. I keep the house about 72, so no furnace most of the time. Only difficulties were when it dropped below zero for a few weeks and our house is quite drafty. Blankets over the drafty doors resolved that issue nicely. There is no damper on Napoleon stoves. There's an air control. I run that wide open at start up for about 1/2 an hour to get the stove up to temp then turn it back to 1 and the stove burns for about 8 hours on a full load of good, dry wood. The stove is rated for 1000-2000 sq. ft. Our house is about 1300. But I believe those numbers are misleading on almost all stoves. It all depends on the layout of your house, air tightness, placement of the unit, number of stories, etc.... While I'm sure a better stove is, well, better, mine works fine for our needs. The energy savings payback on a more expensive stove for me would have been over 10 years. Mine was paid off just short of 5. If I ever build a new home I will probably look at better stoves. Thanks for the info.300 for a STT is too low. You should be trying to keep it closer to 500 or above for cleanest burning. Thats for any stove. You might be running the stove as supplemental heat, and not as the sole heat source for your entire house.
I did have to burn quite hot. The stove was specked to meat my heating demand with a little extra, however in practice it couldnt meet its specs unless it was ran at greater than 1/2 damper. The stove is rated for "2000+ Sqft" and my place is only about 1700 sqft. There should have been some cushion there to allow for drafts and/or different wood.
My new (well 4 month old) stove heats my entire place, using the same wood, with the damper on 1/8 open.
There is NO comparison between my old Napoleon 1450 and the new PE Alderlea other than the fact that they both burn wood!
Over on Hearth.com there are a few guys with the 1450 and they like them. There are also several who dont and have upgraded. Once you get a premium stove you start to see where the corners were cut on the cheaper ones, like the 1450 to make price point. Looking back now, I was penny wise, pound foolish. I should have bought the "good" stove the first time around, and wouldnt have taken a $600 loss on the 1450.
Id never go back to a stove with fibre baffles. PE's baffle system is one of the best out there. Easy to remove too.
