Wood stove problem.
   / Wood stove problem. #11
Highbeam said:
Comeon now, how many bolts, nuts, or studs have you welded on and not died from cadmium poisoning?
Yeah, I silver soldered for 20 years before they come out with cad-free. It really made it flow nice!
   / Wood stove problem. #12
Mega_Me said:
The main firebox door on my add-on wood furnace has developed a small hole. It is a cast iron door. Can it be fixed? I'm probably going to either have a new door fabbed or order a new one. Just wondering.
The hole is located between the L and the A as indicated by the pics.
I would suggest that you contact the manufacturer and see if he can help you with the problem. They might be able to replace the door. Or at least tell you the best method of repairing the casting.
you can reach them here I think?
United States Stove Company
   / Wood stove problem. #13
I've got a buddy that welds cast iron using 1311 (I think) rod. (calls it "farm rod" because he uses it to weld almost everything on his farm)
has repaired his wood stove with it more than once. (not in the same spots)
doesn't even bother preheating, which surprised me the first time I saw it.
Also used to work with a guy in a machine shop who would weld engine blocks, but he preheated them to about 600 degrees and used a heliarc. after welding we reheated the blocks to 600 then put them in a shot blaster to stress relieve. Not real practical here, but it worked.
Adams 16T Tender Body (A55301)
Adams 16T Tender...
2017 Nissan Versa SV Sedan (A55758)
2017 Nissan Versa...
(INOP) JOHN DEERE TS GATOR (A51247)
(INOP) JOHN DEERE...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
(16) SINGLE AXLE FENDERS (A54756)
(16) SINGLE AXLE...
