Wood stove for pole barn
   / Wood stove for pole barn #11
Without insulation and a ceiling, I think you will be spending a lot of effort feeding the stove with very little benefit. However, when you get the building insulated, it will work well. I have an insulated 40 x 48 building with a 12 foot ceiling. I'm using a US Stove 2000 (from Rural King) which is an airtight (mobile home approved) stove. It does a pretty good job of heating the building. I would go to the extra expense of an airtight stove. I pull combustion air from the attic and have a completely vertical chimney pipe. You will need to use double wall pipe from the ceiling surface to the chimney exit which will probably cost $300+. There is no "cheap" way to do this right which is why I spent the money for a new air tight stove. I know that's not what you wanted to hear but you don't want to go to the effort and not get a heated building and you don't want to burn your building down.
   / Wood stove for pole barn #12
Hi,
A couple of Comments. I am surprised that no one has mentioned the problem of condensation and dripping inside the shop without insulation. It is standard practice here in the Pacific Northwest to insulate the ceiling.
The other comment concerns a wood stove. Have you considered a double 55 gal barrel stove? Harbor Freight has all the hardware need to construct one at a reasonable price. Before you put out the money for the hardware please check to see if they are approved in your state. In some states they are not allowed.
However before you do anything, please check with your insurance company to make sure you have coverage for a firewood burning space heater. Also check with your building dept to learn their requirements. No one wants to have their shop burn down because of a faulty installation. Then to really make your day have your insurance company denied coverage because of the wood burning space heater caused the fire.
Hope this helps,
Benjamin J. "Joe" Browning
handymansvs
   / Wood stove for pole barn #13
Here in the northeast I maybe have 1 or 2 days a year I get condensation on the inside. Get a bit more under the open lean too roof though.
   / Wood stove for pole barn #14
For the price and heat, the dual 55 gallon drum kits work great, Sorry, Roy, we have a Vermont castings stove at the cabin, and they work well, and love it for the app. But they take time to put out heat, and the drum heaters produce lots of heat right now and are cheap as well. Yes they will not last many winters, but the replacement parts are cheap.
Here is the link for the bottom part, cheap at TSC
http://www.tractorsupply.com/wood-heaters/united-states-stove-barrel-stove-kit-3192628
   / Wood stove for pole barn #15
We actually heat our house 100% with the same stove and have been for three years now. My house is about 1400 ft, and all rooms are an average of 75-80 degrees fahrenheit on the coldest days here in ice cold New Hampshire. This stove is great, and I bought it on sale at Tractor Supply for $500 with a tax rebate for being EPA approved.
For the Barn, depending on the height of your ceilings, I would be concerned with the heat rising, and escaping. You may want to add a barn style fan somewhere above the stove, to help move the heat back towards where you are working. We have them in the barn to help disperse the heat in the summer for our animals. I do like the idea of the drum stoves as well, but what ever you do, make sure that you use fire-board if the stove is near a wall, and I 100% agree about looking into your local fire code, and insurance requirements. I know that when we installed our wood stove, our insurance company required us to take additional measures above our local fire code. This is the type of fans we use, however they are expensive. You can buy a box fan for about $10-15. CountyLineョ Direct Drive Wall-Mounted Fan, 18 in. Blade Diameter - 1025507 | Tractor Supply Company
   / Wood stove for pole barn #16
I heat my garage with this. The garage is 37x37 w/13' ceiling and is insulated and rocked. I can keep it at a comfortable 65 throughout by running my ceiling fan.
Dave
Thanks for all the feedback. Sounds like I need to raid the piggyback and at least get some insulation in the ceiling ASAP.
   / Wood stove for pole barn #18
United States Stove Barrel Stove Kit - 3192628 | Tractor Supply Company
With a 40 x 60 pole barn this is the smartest set up you can use ,cheap easily replaceable , you can add another barrel to have them double stacked to increase surface area for more heat , no need to have double wall pipe until you go through ceiling or wall with outside pipe chimney , A wood stove would have a hard time to heat an uninsulated 40x60 building and you would be constantly loading it ! keep it simple !
   / Wood stove for pole barn #19
vermont castings make a good stove,can't deny it,but,if I wanted to heat a large building like that,I would look for an old Fisher Grandfather Bear stove.it has double doors on the front,or you can even side load it.they put off tremendous heat being an air tight stove.you can find them for $300-$500,can't buy them new,quit making them in the early 80's,but man are they a good stove ! I heated my 2200 sq ft house with a Fisher Mama Bear,and we were opening windows at times.the Mama Bear will take up to 24",and the Grandfather will take up to 26" I believe.you can't go wrong.with a floor standing oscillating fan by the stove,it will distribute the heat nicely,but don't get it too close,especially if you have the stove banked off with some good ole dry locust to burn.these stoves turn up every now and then,I see them on Craigslist,or you can try searchtempest.com to broaden your search.good old stoves.the other one would be a Timberline,same stove as the Fisher from what I have seen,only difference is the door casting,one says Fisher,the other Timberline,both are great stoves,good luck !
Update for those interested. I started looking on craigslist to see what I could come up with for some cheap insulation, and I lucked out! Found a guy about an hour away that was tearing down some old chicken houses and had salvaged the foam insulation out of the roof. I picked up 120 sheets of 1 1/2" tk Dow polyiso foam 4'x12' for a dollar a sheet. This enough to insulate the whole barn! Thanks to those that urged me to get some insulation before trying to heat it.
Also been searching CL for a used stove, there are a ton out there for not much money, going to look at one this afternoon. Looks like I will be able to work comfortably in the barn this winter after all.
Thanks for all the info and advice.
2025 Icon Golf Cart (A42744)
2025 Icon Golf...
MISC PALLET OF BOP PARTS (A45046)
MISC PALLET OF BOP...
7’X20’ METAL DRIVEWAY GATE (A45046)
7’X20’ METAL...
1995 TRANSCRAFT 45’X96” FLATBED (A45046)
1995 TRANSCRAFT...
2004 Mack CX613 w/ Diesel Engine (A44789)
2004 Mack CX613 w/...
2014 DODGE RAM 4500 (A45046)
2014 DODGE RAM...
