Wood Splitter?
   / Wood Splitter? #1
Dirk
Western Chicago Suburbs
Can I hook up a standard hydraulic wood splitter to a BX? Thinking about getting a BX2200, and wondering if it'll help with this chore, too.
   / Wood Splitter? #2
You could hook up a splitter. However, keep in mind how much flow your system has.
I looked into this for my B8200; I found the 6gpm pump rather insufficient compared to the higher flow pump on the stand alone units. The low gpm would result in a very slow splitter cycle time.
RobertN in Shingle Springs Calif
   / Wood Splitter? #3
I've thought about this too, for the tractor of my dreams (still in my dreams /w3tcompact/icons/frown.gif). I found a couple of splitters with their own pumps, powered by the PTO, so they are independent of your hydraulic system. Sorry I didn't save the URLs, but you should be able to find them with a web search. I doubt the BX has enough hydraulic flow to give satisfactory results otherwise.
John
   / Wood Splitter?
Hmm, I never thought of that. Run one off the PTO.
Does anyone out there have any exprience with a PTO driven wood splitter, and do you think the BX2200 has enough power to do that?
   / Wood Splitter? #5
<font color=blue>do you think the BX2200 has enough power to do that?</font color=blue>
That would depend on the splitter, but most portable splitters (that I have seen) have an engine a lot smaller than the one on a BX. So I would guess that for many of them, the answer would be "yes".
The GlueGuy
   / Wood Splitter? #6
By golly More than enough power, (depending on the displacement of the pump). I use a Cessna 20 gpm pump (salvaged off an old Case loader), hooked to a PTO coupler, running at 1000 rpm (pump maximum speed is 1200). I can get cycle times (up and back) of less then 10 seconds, but I usually throttle it down, or run in the 540 rpm setting. Usually I run the Kubota at 2000 rpm and go with the slower cycle times. (Using a 4" cylinder, peaking at 1500psi.)
I once tried (it was a learning experience) splitting gum, or should I say 'splintering' gum. Results were not very pretty, but the power was there.
The advantage of the Kubota is fuel economy. When I used the setup on my Case SC (19 HP) I'd use at least 2 gallons (gas) per hour (usually more). A friend using a B&S 10HP aircooled (very similar setup) is using about 1 gallon of gas per hr. Using the bota, its less than 1/2 gal of diesel per hr.
Steve
   / Wood Splitter?
Steve, where do I find one of these PTO driven models? Can I rent them? Seems like everything i see to split wood, is hydraulic.... Are the PTO models out there, or are they always built for self use, by someone like you?
Pequea HR10 Rotary Rake (A50774)
Pequea HR10 Rotary...
2009 Champion C80 B Motor Grader (A50322)
2009 Champion C80...
Ford 5610 (A50120)
Ford 5610 (A50120)
2016 Ford Explorer...
(2) Military Front & Rear Differential (A50121)
(2) Military Front...
2014 INTERNATIONAL MA025 (A52472)
2014 INTERNATIONAL...
