wood splitter
/ wood splitter #21
Take the lever off where it hooks to the valve body, but leave it hooked to the spool. Now push handle hard to move spool all the way in, then pull hard. Dead head the cyl both way and if no psi then it's the valve, could be a motor spool valve.
/ wood splitter
Your relief valve should be set to about 2950 psi.
Your two stage pump is capable of 3000 psi.
What pressure do you get at the end of the extended stroke?
Did you remove any of the relief valves to inspect them. If so, did you put all the parts back together correctly?
J-J
1- What pressure do you get at the end of the extended stroke? answer - 500-600 psi
2 - Did you remove any of the relief valves to inspect them. If so, did you put all the parts back together correctly? answer - I did not remove anything from the relief valve, only loosened the lock nut and adjusted the allen head screw in and out. And you are right to question me if I: "Put all the parts back" -----That would describe my luck to a tee, but I can without a doubt plead innocent to that one this time:)
/ wood splitter
Leejohn
You have to remember I am a carpenter by trade. I fix and build things by hitting them with a hammer and if given instructions otherwise, I can get confused very easily:) I understand the unhooking of the handle from the valve body and then pushing and pulling of the spool. Just not sure about the dead heading. Am I to dead head the extend port with a gauge in it like you had me do before and then just plug the opposite valve port? This would completely take the cylinder out of the system.
/ wood splitter #24
This is the log splitter valve he has installed.
Prince log splitter/lifter valve (RD522CCEA54B1)
If the relief works in one direction, it should work in the other direction.
Can you disconnect your log splitter cyl and connect it to a tractor valve and see if it functions correctly. If it functions correctly, then the valve is at fault
/ wood splitter
J-J
I do have a loader but would have to purchase more hose for testing. I do not know if I followed Leejohn's instructions correctly, but I get the same result all the time. I dead headed the extend port with a gauge and plugged the opposite port, disconnected handle from valve body, pulled spool in and out with the same result as every other test. The gauge in the extend port still only reads 5-600 psi when spool is positioned at extend port.
You mentioned cylinder condition and here is another test I did to which I thought would show cylinder condition is o.k.: With everything back together where it is supposed to be, I reversed the hoses on the valve body so when piston is fully extending you do not have to hold the handle, it would kick out when piston was fully extended. Then if I over ride the detent to try to extend piston further so I could get a pressure reading, the pressure shot up to 2,000 psi. Which seemed to show the cylinder was holding pressure. At one point I even placed a 4-5" piece of Tamarack cross wise the wedge and the piston sheared it about 3/4 of the way through before I could stop it. Would that tell you that the cylinder is likely o.k?
So no matter what I do, the extend port will never give me a pressure above 5-600 psi and which takes a short time to build up to that. Yet the opposite port for that same spool will easily and very rapidly give me 1500-2000 psi. And the log lift spool, on the same valve body, will give those higher psi reading in either of it's ports very quickly. So three ports on the same valve will give high pressure but one will never give over 5-600 psi.
Maybe I am missing something in telling you about this problem.
/ wood splitter #26
You are stating the problem as you see it.
I agree, your problem does not make sense.
Why the cyl will not make relief pressure in the extend mode is puzzling.
Can you switch the hoses and use the log lift to operate the splitter cyl to see if the extend mode will build up relief pressure.
/ wood splitter
J-J
Good idea, I will try that as well.
/ wood splitter #28
Where do you have the pressure gauge mounted. It sounds like you are moving the gauge around to different ports. The gauge should be installed between the valve and the pump. Mounted on pump side of valve will let you adjust the reliefs. You have pressure at the pump to valve per your other posts. If your cylinder is good, and you cant get pressure to the cylinder, the problem is your valve, or your plumbing, or reliefs not properly set. When you deadhead the valve and it goes to 5-600psi, will it continue to climb if you continue to pull the lever. If so, could be the valve isnt going all the way in for full flow. If not, then relief is set to low, bad, or has internal leakage, (cracks internally are not unusual, altho not all that common). Someone already suggested to remove valve handle and try to push the spool to see if it will go in farther than it will with lever attached. have you tried that?
/ wood splitter #29
The pump is capable of 3000 psi, and he has already seen 2000 psi on the gage .
The gage should be installed in a tee in the IN port of the log splitter valve. That way, it will reflect any pressure in the circuit.
The gage came from the factory set to 2000, so it appears the relief valve is working and relieving at 2000 psi.
The puzzling part of all this is that he can obtain 2000 psi on the retract if held open.
It does not make any difference how much lever is applied, as any GPM should make the cyl build up pressure under load.
If the cyl can not build up pressure to the relief limits, there is a leak somewhere .
Once he uses the log lift ports to verify the log splitter cyl, we will know if the problem is the cyl of the valve.
What kind of pressure are you getting on the log lift cyl?
/ wood splitter #30
JJ, I agree with you. My suggestion to hold the lever long enough is based on partial engagement of spool valve will allow low flow and low pressure readings until resistance is met. Continueing to hold the lever engageing the spool will let pressure built to relief setting, albeit somewhat slower than if the spool was completely engaged. Once total resistance is met pressure should rise pretty fast. As I under stand it, his switching of the hoses to the cylinder, the system will build full pressure on both sides of the cyl piston, depending on which end he currently has the hoses connected to. I think that eliminates the cylinder as the problem since he has stated system pressure at both ends of the cylinder. The pump is building system pressure as set by the relief at 2000psi, You are right, if the relief works in one direction,it will work in the other direction, the oil flows over the relief in the same direction, requardless of which direction the spool is centered. I think that narrows it down to either a defective control valve, or improper plumbing. The problem seems to be only on one port/direction of the control valve, could be a crack internally allowing oil to flow back to tank which would negate any attempt to adjust pressure at the relief.
/ wood splitter
Thanks for stepping in muddstopper. I do have the tee with the gauge installed between the pump and valve. It is right at the 3/4" inlet to the main valve housing. I only moved it to the extend port to make the test Leejohn had suggested. I have also kept the lever engaged for a long time to see if it would build higher than the usual 5-600 psi, but it does not.
Now in reading both your posts and J_J's recent posts, I may be at fault for saying something in my testing results which is not true, but you are taking for granted it is true. And I do not know if it even makes a difference to your finding a solution, but J-J, in your recent post you said: "The gage came from the factory set to 2000, so it appears the relief valve is working and relieving at 2000 psi." That is not really true, whenever I am testing and the pressure goes up to 1500-2000 psi I have always stopped what I was testing, thinking I might bust something. So I do not know if the main relief is really working. All I know about that relief is I can screw it in or back out and I will always get the same slow build up to 5- 600 psi. While in other tests the pump, cylinder, and 3 of the 4 ports have tested 1500-2000 psi. very quickly.
When I can switch and test the log lift spool on the main cylinder, do you want me to rev the engine and see how high the pressure will go since I know the log lift spool has show me it easily hits 1500-2000. Would I damage anything or would it just kill the engine?
/ wood splitter #32
If the relief is working, it will not kill the engine as you are relieving at 2000 psi and at that pressure, you are not using all the the engine HP.
Your engine and your pump was selected to provide the specified GPM and pressure.
At 3.4 GPM and 2000 psi, you are using only 5 HP.
By the way, your detent is preset to 1200 psi, and the adjustable main relief is from 1500 to 3000 psi. When the cyl is maxed out at the indicated 2000 psi, turn the main relief in and the pressure should rise. You are simply tighten the spring on the relief valve to provide more force, if the cyl can make that force.
The speed of the engine only controls the GPM. The resistance to the flow dictates the pressure.
Yes, hold the lever to maximum to get the maximum pressure allowed by the relief valve.
You might check the load checks valve on the log splitter spool. That is under the hex plug between the work port. When they go bad, you get strange results.
Check the poppet, spring and the seat for debris.
/ wood splitter #33
I think the spool isn't getting moved far enough or it's the wrong spool or body is cracked.
/ wood splitter #34
Again, the spool position does not matter.
Any flow will fill the cyl and when it meets resistance, the pressure will build up until the relief pressure is met.
GPM's determines the speed of operation. Pressure determines the force.
/ wood splitter #35
/ wood splitter #36
JJ is correct, it doesnt matter how far the spool is moved, it still should build maximum pressure, it will just take longer because of restricted flow. I am leaning toward valve problems myself, but I just skimmed thru the threadt. I am going to reread the thread before commenting further.
edit,
after further review, unless the splitter has a dump valve plumbed in the system, and it plumbed wrong. I still think it is a valve problem. As far as factory relief setting on the valve, it doesnt matter (for testing purposes), if its set at 2000 or 3000psi, You still should see the same pressure in either direction the valve lever is activated. When you change hoses at the cylinder,the problem moves with the changes. You have pressure at the pump, your cylinder will allow pressure build at each port, only thing left is the valve. With that said, if the splitter has a dump valve to allow oil to bypass the control valve on return stroke and it was plumed on the wrong line, then pressure could be flowing thru the dump valve back to tank, not allowing full pressure to build. I doubt a splitter with a 11gpm pump has a dump valve, but it is a possibility. The control valve should have a in, (pressure),out, (tank) and 4 ports, one port for each port on the two cylinders. Is anything else plumbed into the system?
/ wood splitter
Thanks J-J I will see if I have time tomorrow to test these things out.
/ wood splitter
edit,
muddstopper
Made a comment earlier to you but do not see it so will try again. I do not have a dump valve or anything else plumbed into the system. It is a very simple system. Oil from the holding tank, to the pump, to the tee and gauge next to the main valve, then into the main valve, then out the other side of main valve, then through the filter, then returning to the holding tank.
/ wood splitter #39
I didnt think you would have one, but just wanted to make sure.
/ wood splitter
J-J
Had a short time to work on the splitter this morning. (I thought if I retired I would not have any more dead lines:) Removed hoses from log lift side of valve and replaced them with hoses from the main cylinder. Levered in and out and seems to work perfectly in both directions. Been cold around here and oil was a little thick but the gauge read 1500 psi at either end of the piston stroke. Fairly fast up to 1200 psi and then slower build up to 1500 psi. Did not have time to try and raise the main relief psi. What do you think, new valve?
HONDA Plate Compactor (A64557)
HONDA Plate...
UNUSED SDLANCH SDL2030GT-20' X 30' PREMIUM HEAVY (A64281)
UNUSED SDLANCH...
2011 Terra Riser 300D-SA Fire Plow Attachment (A61572)
2011 Terra Riser...
2014 FORD ESCAPE (A66091)
2014 FORD ESCAPE...
(INOP)1989 NISSAN D21 EXTENDED CAB TRUCK (A64280)
(INOP)1989 NISSAN...
Unused 2022 Hustler Lift Max LE110 SS Bale Forks and Frame Tractor Loader Attachment (A66734)
Unused 2022...
