Wood splitter hydraulic question?
   / Wood splitter hydraulic question? #1
lennyzx11
Bennington Vermont
Kubota L3301 HST/LA525 & 1964 Ford 2000 gas
I have added a 2nd prince valve to my wood splitter to run a log lift. Both are same valve.
They are connected pump>1in>1out>2in>2out>tank.
The puzzling thing is when I first nudge the #2 valve, the lift seem to power(not coast) down slightly. I give the handle a bit more movement and it responds as expected going up. Valve 1(splitter) is in neutral.
Both valves are connected to DA cylinders.
I’m not sure why that bit of drop occurs when #2 is cracked to go UP.
At first I thought maybe air in cylinder 2 from the install but after exercising it through a couple of bucket loads of wood, it still does it.
Ideas?
Lenny
   / Wood splitter hydraulic question? #2
Ideas?
Lenny
Your plumbing is completely wrong!!!!
First, your first valve in line needs to have a power beyond circuit. This is usually an optional sleeve or plug which you buy and install. Since your latest valve is the newest, see if you can buy a power beyond kit for it.
The power beyond option is to feed or provide an IN or Pump port for the second valve in line.
You should never use an OUT port of one valve to feed another. OUT or TANK ports are only designed to handle around 450 psi and when the second valve calls for pressure the first valve's pressure on its TANK port will greatly exceed its rated pressure.
Dave M7040
   / Wood splitter hydraulic question? #3
If you are trying to feather the raise....it won't develop enough pressure to overcome gravity acting on the cylinder without more flow.
Loaders have anti-drop valves to prevent such a thing from happening when trying to make precise movements.
Also, the valves in series like that isn't a good idea. You really need a power beyond first valve to feed the second valve. Or should have gotten a 2-spool valve to handle both rather than adding a single to the system.
But regarding the dropping....you'd be better off either using a restrictor fitting with orifice or even a flow control valve to Taylor the speed to your liking. Then you don't have to easily feather the valve
I was afraid of that. I am getting a 2 valve block but also had read numerous accounts of how it worked fine.
Dave I believe you. But it doesn’t seem like the valve itself would have a lesser pressure rating on the Out port. The pump is designed to put out 2500 psi. I see where the OUT fitting and Line to tank is rated only for tank pressures but I installed the nipple between in and out as a 6000 psi hydraulic fitting.
Are you positive on that? You’ve given me great advice over the years so I trust you completely but don’t see how.
   / Wood splitter hydraulic question? #6
The tank passages within the valve casting are nearer to the outside...and often much thinner than the pressure port passages.
The valve itself is not rated to have pressure on the tank port. If you do....you run the risk of cracking the housing....or blowing the end spools out of the valve and have it constantly leak.
It all has to do with the inner construction of the valve and is not something you can see.
A log lift....depending on your geometry.....may not take much more than 400psi to operate. So people may get lucky. Still doesn't make it right. And if you ever deadhead the cylinder you are spiking the pressure.
The simplest thing is to get a 2-spool loader valve. They usually have load-checks. Which the dropping of your lift table when trying to feather slowly was the reason for your post in the first place
   / Wood splitter hydraulic question? #7
Dave M7040
Do you know when power beyond was introduced to farm equipment hyd systems? I don't remember PBY being on farm equipment when I was employed by a JD dealer '66-'87 BUT I was more involved with closed-center hyd systems than open-center hyd's. I've seen several older tractors with single spool valves connected in series to form dual/triple spool valves with no PBY similar to how Lenny attached his valve. I also agree with LD1 & think a check valve will solve Lenny's hyd problem
   / Wood splitter hydraulic question? #8
Firstly, if you want to add another valve bank inline with the first valve bank, the first valve bank must be fitted with a power-beyond sleeve, and the first valve bank must have an integral relief valve built in or one connected externally to the "P" line correctly.
Why both components?
The tank port of the first valve bank must be free to allow the relief valve to relieve to tank without back pressure, and to allow the returning oil from any operating cylinder connected to the first valve bank to return to tank also.
Now the power beyond sleeve.
This externally fitted sleeve in the first valve bank virtually allows high pressure oil from the pump to continue directly through to the second valve bank without interfering with any relief or returning cylinder oil in the first valve bank, freely able to go back to tank via the alternate "T" port.
Internal load-holding valve.
Some cheap valve banks do not have a load-holding check valve in the internal high pressure gallery, and as such, during the initial shifting of the spool, oil in this HP gallery is momentarily allowed to leak back to tank with the returning oil. This is why the load may drop a little before it is raised.
   / Wood splitter hydraulic question? #9
I have used the same set up you have for the past ten or more years on my splitter and it works just fine as long as you do not try to use both functions at the same time. As stated when you try to feather the load gravity will take over until you apply enough hydraulic pressure to compensate for the load.
For those folks who say it will not work I just finished splitting three cords of oak yesterday.
I am waiting on a AutoCycle valve with Power Beyond that’s on perpetual back order to install as Valve1.
This is more a case of some people says it works fine and some doesn’t. I had the pieces, the shop was warm from the wood stove, so I wanted to see for myself.
I do understand now that the tank passages may be milled to not have the same bursting strengths now per explanations. Thank you.
And a check valve in log lift plumbing would compensate for the gravity drop.
Thanks for all the education. As I said I don’t intentionally want to build something that will damage or hurt somebody but want to understand when a lot of “very” knowledgeable people are opposed on views on it works, not safe, been that way forever, etc…
Lenny
SULLAIR 185 PORTABLE AIR COMPRESSOR (A51406)
SULLAIR 185...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2009 Chevrolet Traverse LS SUV (A51694)
2009 Chevrolet...
2019 Chevrolet Tahoe LT SUV (A51694)
2019 Chevrolet...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
JACTO ARBUS-1000 LOT NUMBER 71 (A53084)
JACTO ARBUS-1000...
