wood spliter
   / wood spliter #1
dixstir
fairmont mn
2305 jd cub farmall home made tractor
just finished my splitter today so we are having a trial run to see what it will do 3-1/5 cylinder 11 gal 2 stage pump (nothern) 11 briggs works good and pretty fast now the problem a @ 600 psi on the guage it will not make any more psi dont want to go into next stage.any advice?
   / wood spliter #2
It is stuck in the high speed mode.
If it is a new pump, send it back.
There is a pressure sensing device inside if you wanted to tear into it. It just might be jammed up with some debris/trash.
Did you max out the cyl to see if the relief came on?
If you were splitting pine or some light weight wood, it might not have had a chance to go to low speed, high pressure.
   / wood spliter
the pump is used I put a guage in line can only get about 700 at wide open (3200rpms)
   / wood spliter #4
You still did not say if you held the lever at the end of stroke to make the valve go into relief, and develop max pressure.
Relief pressure is usually around 2300 psi.
   / wood spliter
the cylinder was maxed out right up to a chunk of wood engine was laboring maybe 3200 rpms an the guage was about 700 psi.
   / wood spliter
thats the one the breakdown is good thanks for the help maybe I can take it apart and see what the problem is .thanks
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
Komatsu WA250-5L Wheel Loader (A52384)
Komatsu WA250-5L...
2013 FREIGHTLINER CORONADO TANDEM AXLE DAY CAB (A53426)
2013 FREIGHTLINER...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2024 JOHN DEERE 35P LOT NUMBER 107 (A53084)
2024 JOHN DEERE...
