Midniteoyl
Elite Member
- Joined
- May 20, 2013
- Messages
- 4,929
- Location
- N. W. Indiana
- Tractor
- Kioti CK3510SE HST, Ford 3400, Gizmow ZTR, Simplicity 7016H
The simple butterfly type or spring loaded backdraft dampers work and are cheap, assuming two air handlers which is what i think you described...
But, if you have rectangular ducting, and the oil burner comes in vertically from the bottom, a simple flapper valve placed over the duct angling in would do the same. A simple piece of sheet metal covering the entrance, hinged in the rear. When the air from the oil burner is moving through it, it will be pushed 'up', when not, it will fall back down due to gravity. You can line the flapper with foam to seal and quiet it... Simple.
If the duct comes in hortizonally, a very light spring could take the place of gravity, though prolly not needed as the pressure would 'hold' it shut.
edit: picture to give idea, though I would make the flapper big enough to touch the other side of the dict at an angle so as to not worry about it 'making a seal' against the other hole.
