Wood Foundations and Ground Water
   / Wood Foundations and Ground Water
Its in MI. The wood used is dimensional pressure treated pine. I looked at the USDA soil survey may and the soil is classified as Capac Loam.
You guys have made some good points so far. Roman concrete is still around, but I also remember seeing a documnetry that said Venice was built on wooden piers sunk into a swamp. Dave has a good point about skepticism in future buyers if I were to sell the place in the future. He is thinking a little farther ahead than I was.
TCrowner sounds like he is living in a wood foundation in similar soil, and happy about it. And I have seen some cracked and wet masonary foundations. One I looked at last week had water along the base of the wall in a 2002 built walkout basement that should have had the grade working to help it.
Normally I would run away from anything that looks questionable, like MossRoad suggests, but what gets me about this place is that even though the guy is dead, its easy to see he was meticulous in every detail. I am guessing he worked in the electrical field in some capacity. The wiring, panels, sub panels, and even an exterior service disconnect at the meter socket are all done very neatly with every wire labeled. Outlets and switches in everyplace you could want. There is even door contact switches that turn on the lights when you open the closet doors. The heating and A/c are top of the line with zoning. There is an air to air heat exchanger for the exhaust fans. The well tank is huge, kitchen has built in wall ovens, the windows and doorwalls are high line Andersons. Rooms are all generously sized, and all the trim is good quality. The roof is original and looks in great shape. The barn is two story with a walk out deck on the second flloor, And he has nice built up work benches and shelving. Everything I see says he wasn't cheap skate. I wish I could ask him why he chose a wood foundation.
I do like the idea of asking who the builder was and seeing if I can talk to them. Home inspectors never have impressed me.
   / Wood Foundations and Ground Water #12
The problem with anything non-standard in housing is, whether it is perfectly fine or not, the market has skepticism, as you do. It was cheaper and faster to build, it should be priced as such. You would be taking on the ownership of that market skepticism.
Good point. Try to find a "standard" house inspector, that's "local". He will tell you first of all, what he's seen in other houses in the area, and how they've fared. And furthermore, you will find out what the local inspectors tell other buyers, which if you sell, you need to know. If he's a busy inspector, and he sees lots of _____ foundations, he will be able to tell you if they work ______ in your area.
The house you want, and the location you want, and the price you can afford, and the schedule, are far more difficult than inspection. Inspection is about the cheapest and most expedient part of the process, just hope you find an inspector who's experienced and practical. Agreed some home inspectors are hacks, you need referral. And not from a real estate agent, those referrals are geared toward keeping the sale moving ahead. Anyway it sounds like you can do a lot of the inspection, and capable to evaluate, or second-guess your inspector's comments.
   / Wood Foundations and Ground Water #13
I can tell you that a lot of houses in my area have been built with treated wood foundations. The chemicals do not stop rotting - of which there are numerous causes.
I know of four families that have had to remedy the rotting foundations with concrete - an expensive process as well as a lengthy process. It can be done using a good contractor.
I guess it boils down to what you want and how badly you want the property.
Inspectors are easy to find. Getting just one opinion doesn't do much for you. Perhaps contacting architects or civil engineers might help, but the bottom line is the foundation is wood and will be prone to rotting or insect damage eventually.
My take is that your wife has fallen in love with the property and that goes against any rational decision making.
From my limited experience on buying houses is to give this property a failing grade. When in doubt walk away - there is nothing you can do if you buy it and the worst happens, except kick yourself hard and get the check book out.
There will be plenty of other places for sale and you will get what you want without the uncertainty and worry of a possible foundation failure.
Just my two cents. I hope you make the right decision.
   / Wood Foundations and Ground Water #14
With a inspection report it gives you leverage to reflect the cost of replacing the foundation in the offer of the price.
   / Wood Foundations and Ground Water #15
One concern I would have is resale , my neighbor has a wood foundation and the house has been on the market for over 2 years , can't find a buyer and it is a nice home on a very nice piece of ground .
   / Wood Foundations and Ground Water #16
My wife and I looked at a house with a wood foundation last summer. The land all around the house was pretty flat the exception being the location of the house, it was built on a big pile of fill dirt and sand. The wood foundation was heaving and buckling in various parts of the basement which was finished. The house and property were absolutely gorgeous!! When I read your post I thought you were looking at the house I looked at:laughing: In my opinion, the house I looked at, the foundation was not properly installed. I have only seen one other house with a wood foundation too new to know what will happen with it. Not having a sump pit in my area would worry me. Like the others have said, do your research and don't buy it on emotion
Thanks everyone for your input, you've helped to solidify a decision. I am going to forget about this place and move on. The biggest factor for me is future resale-ability. Right now it's a 17 year old wood foundation system. In 30 yrs it'll be a 47 year old wood foundation. By then, time will have had alot more opportunity to work on anything that wasn't done just right. And wood will not stand up to the challenge as well as concrete. It scares me a little, and I'm sure it would affect a future buyer's impression of value. You guys hit the nail right on the head for me.
My wife is not going to be happy about this, but that discussion would be best saved for another thread. We have 8 kids and she really wants to stay in the same school district, and keep all of our service providers like doctor and dentist and such. That makes our pool of potential homes smaller.
   / Wood Foundations and Ground Water #18
Be careful about Forum advice. It is often skewed from the viewpoint of someone who has not SEEN the subject at hand. It often chooses to err on the side of caution, and frequently, extreme caution. And when fear of the unknown turns out to be unfounded then it's just "oh well, didn't want you to get stuck with a lemon,,,,". They do want to help but they're assuming an unlimited supply of suitable homes and that your wifes happiness is trivial. Its not.
Anyway you seem observant and capable. Foundation problems can be insurmountable for some, and solvable for others. Consequently one guy says buy and the other says walk away. And its quite possible that there are things an observant guy can do now to eliminate future problems.
Good luck. Moving is both disruptive and exciting, makes you push the reset button.
   / Wood Foundations and Ground Water #19
Even with a concrete basement you have to pay attention to the construction of it. Poured concrete and concrete block foundations seep and crack. They don't last any longer than any other material if not protected and built properly. Your water proofing is drainage is your key.
   / Wood Foundations and Ground Water #20
I think you made the right choice.
There is no comparison of the costs of fixing a wet concrete basement and jacking up a house and replacing the wood foundation. Since both are potential risks, the less $$$ risky choice is the concrete. We can't eliminate risks but we can sure compare them.
A concrete foundation that is 10 years old and in good shape has a much better chance of still being in good shape 25-30 later than a wood foundation IMHO. Even if you had to dig up and replace the footer drain around a concrete foundation that is minor compared to jacking a house and building a foundation below it. Not to mention the house would not likely be livable for several weeks once it is jacked up.
EDIT add: What would make sense if you really want the property, is to buy it for $20K to $30K less than a comparable property in your area. Then hope for the best but be prepared for the worst. Risks have a value.
2009 JOHN DEERE 135D EXCAVATOR (A51242)
2009 JOHN DEERE...
2016 Nissan NV200 Cargo Van (A50323)
2016 Nissan NV200...
Cat 315l Excavator (A50514)
Cat 315l Excavator...
2019 New Holland C227 Skid Steer (A50657)
2019 New Holland...
2013 JLG 8042 TELEHANDLER (A50854)
2013 JLG 8042...
2018 Dodge Charger Sedan (A50324)
2018 Dodge Charger...
