Raider43
- Joined
- Feb 8, 2012
- Messages
- 91
- Location
- Newtown, Ct
- Tractor
- Kubota L35 "1998",Kubota RTV900 "2010", Samsung SE210LC-2"1998" AM General M817 dump truck "1972" John Deere 450B "1998"
See alsoSo I see bearcat, woodmax and jinma along with I think Wallenstein Bx42r or 62r. although the I think the 62r is too big for my tractor, yes? Are the two blade systems sufficient to do 3-4 inch maple and oak? Paul
Paul
I have the Wallnestein BX42 and have been very happy with it. If you really intend to cut 3-4 material I think you need to have a six inch size chipper. Material that size goes in my firewood pile. I occasionally have issues with twisty and forked 1 or 2 inch stuff with my "four inch" machine. Things that are twisty tend to get wedged in the chute before they make it to the blade.
I can tell you my 30HP B3030 handles the BX42 without any trouble at all. I have plenty of power for my use. It chips faster than I can bring sticks to feed it.
I have a Wallenstein BX42s PTO drive chipper running off my Kubota B3300SU with 33-hp/25-hp PTO. A good match. I paid $2599 (plus shipping) (January 2012) from Iowa Farm Equipment, via eBay...not too far above your budget.
Plan on buying or building a caster dolly for your chipper. I bought my first caster dolly, 36" X 24" solid deck /1,200 pound capacity, from Northern Tool via eBay. Dollies wider than 18" are difficult to find, that is why I have mentioned Northern Tool. I am in the process of building a second dolly to mobilize a Ratchet Rake from four used industrial casters I bought on eBay for $30 delivered. The Wallenstein BX42s weights 425 pounds....very difficult to maneuver onto the three-point pins and tractor PTO stub if it is sitting directly on the floor. See following link:
http://www.tractorbynet.com/forums/build-yourself/242128-heavy-duty-industrial-casters-ebay.html
I cut off dirt encrusted roots from saplings before I chip them. I amputate them with a Milwaukee 28 volt battery powered Sawzall, then burn them. This is an extra step but if you keep dirt away from the chipper blades they chip a long time before they need to be sharpened. The four blades on the Wally probably contribute to long periods between sharpenings.....share the load.
I own both a Mighty Mac and Wallenstein unit.
The reason why I went with a Wallenstein BX62S over a Bearcat or any other brand is the shear bolt instead of belt driven. To me, replacing a 5 cent bolt is easier then replacing expensive belts, that either have to be made, or ordered from a dealer - expensive.
