wood butcher
   / wood butcher #1
mjc
Hillsdale N.y.
john deere 990 tlb
990 shim kit
I have a J.D. 990 tlb , I was wondering if anyone has installed a hydraulic shim kit
in a 990, I know that they make the shim kit for the 790 , but I can not find any listing for a shim kit for the 990 at the dealer. Or if any ideas how I could increase hydraulic pressure by 10 to 20%. Also has anyone had trouble with a
8b hoe sagging while in use ,( dipper stick and outriggers falling slightly while in use)? Many Thanks
   / wood butcher #2
Welcome to TBN:D
BEFORE you worry about raising the pressure-get a gauge setup and find out what yours is set for now. I am not sure if the 990 uses shims or just a screw and jamb nut to set the PRV.
Cylinders leaking down is usually a sign that need rebuilding. Seal kits vary in price from $25 to $100 at the dealer or you can find a local shop to get the rebuilt.
Hopefully you will get some other views, your post title is a little strange:confused:
   / wood butcher
Thanks for the help Kennyd, Sorry about the post title , I will check the hydraulic pressure 1st, I believe it should be fairly close to the factory spec's,
I don't see any jamb nut to adjust the hydraulic pressure , thats way I am guessing it is like the 790 and uses a shim kit.
I did talk to the dealer about the back hoe , and their suggestion was to
install a back flow valve, Their thought was that it would be unlikely to be the seals because all the cylinders drop at the same rate , they don't drop that quickly but over an hour they drop 3-4 inches or so , this has done this since it was new.
2016 Ford Fusion S Sedan (A53424)
2016 Ford Fusion S...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
(INOP) 2017 CATERPILLAR 299D2 SKID STEER (A52705)
(INOP) 2017...
UNUSED FUTURE HWG44 - 44" MINI HYD WOOD GRABBER (A54757)
UNUSED FUTURE...
2017 Chevrolet Colorado Crew Cab Pickup Truck (A53422)
2017 Chevrolet...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A54757)
UNUSED RAYTREE...
