Piston
Elite Member
I'm with Furu on this one...
The fact that your going through 200 shear pins, in a LIFETIME of using the cutter, (let alone only 3 years) indicates that you are not using this equipment for what it's designed for. You really need to listen to the more experienced guys here and understand that this is operator induced damage rather than equipment not living up to it's expectation. I know it's frustrating for you and I understand why, but the sooner you realize that your not using the proper equipment, or not using it properly, the better off you'll be.
As for the LP unit not getting nearly as beat up as the Wood's unit, if you truly are doing the exact same thing the exact same way, and getting that much different results, then I'm completely lost in how to explain that.
Have you thought of using a flail mower and cut about 6" high, over the rocks? You may still get a nice cut if all your mowing is grass and small stuff. You can't expect to mow grass and rocks and have a good finish. The guys are right, there is nothing designed to be able to do that. I mow through a LOT of rocks, but the difference is, I don't expect that same mower to cut cleanly in a field of grass.
