Won't start
   / Won't start #1
8510inthewoods
Damon Texas
Boomer 25
I have a Boomer 25. Turn key and all of the lights on dash seem normal, wait for glow light to go out, turn to start and nothing. It is like I've got the Mid PTO engaged or not sitting on the seat. I checked the PTO safety switch; jumped it and it made no difference. I've lost my manual too so I can only find the little four pack of fuses under the front cowl. Replaced one blown 10 AMP but no difference. Any help would be greatly appreciated::confused3:
Thank you
   / Won't start #2
I had the exact same problem with my T4.75 a month ago. Go find the starter and see if a electrical wire that plugs into/near the starter has come loose.
   / Won't start
Well I looked, took the side cover off to be able to get to the side, and found three small and one large gauge wires going to what appears to be the starter solenoid on top of the starter. There was also a 40 AMP fuse. All checked out fine and still nothing.
Any other ideas folks???
   / Won't start
   / Won't start #5
The large wire to the solenoid is the battery cable. Are you getting 12v or more at that cable on the solenoid?
   / Won't start
Yes 12DC to the large wire without turning the key switch
JOHN DEERE 750 (A58214)
JOHN DEERE 750...
2015 Lincoln MKZ Sedan (A56859)
2015 Lincoln MKZ...
2017 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2017 Ford F-150...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
2021 CAT SKID STEER (A55973)
2021 CAT SKID...
Butterfly Artwork (A55758)
Butterfly Artwork...
