wont start
   / wont start #1
EddieDial
I stalled my L 3430 while bush hogging, now it won't start any ideas?
   / wont start
No, I disengaged the PTO, and it cranks, and it does sound like its out of fuel, but I dropped the fuel filter, and even cracked the lines to the injectors to make sure, it seems to be getting fuel.
   / wont start #5
Can you hear fuel control solenoid engaging when ign switch is turned to "on"?
   / wont start
Jim, I pulled the return fuel hose and It seemed to have plenty of pressure so today I am going to bleed the injector lines (again) just to make sure its not a fuel issue, whats next if I'm getting fuel,and thanks to you and Wolfy for the help, I work so I may not always be able to get on the forum right away.
   / wont start #7
May not be related at all but 2 different things have happened while running Kubota 9540 in rough conditions. 1- Something snagged the fuel lines under the tractor and pulled them loose from the fuel tank. 2- Something somewhere on the right side of the tractor is a small triangle shaped thing if I remember correctly. It can be in one of 2 positions. One position and it won't run. Buddy fixed it so I really didn't see it. Not sure if it's a fuel cut-off or what
2007 Volvo VNL Truck Tractor (A53473)
2007 Volvo VNL...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
ASSET DESCRIPTIONS & CONDITION (A54313)
ASSET DESCRIPTIONS...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
2012 Seal Rite SR 1000, Tandem Axel Trailer  (A52384)
2012 Seal Rite SR...
