Won't Start or Run Without Injector Pump Bleed
   / Won't Start or Run Without Injector Pump Bleed #1
Riddler
Sonoma County, CA
New Holland TN75VA, New Holland TC45DA, New Holland TC18
My TN75VA stops running or won't rev past minimum after operating normally for a period (e.g., 30 minutes). Often, just before the engine quits altogether, it suddenly drops rpm to bare minimum and won't respond to movements of the throttle. Then, after the engine dies and won't restart, we often, but not always, can get it running again by disconnecting the feed to one of the injectors while we turn the engine over. However, this last time, disconnecting the injector feed didn't enable the engine to start back up. Instead, I just let the tractor sit for a week and it started back up without disconnecting the injector feed.
It has been suggested to me that intermittent symptoms of the type I am experiencing can arise after the injector pump is exposed to water tainted fuel. I do change the fuel filter from time to time, and the old ones have always been intact following removal.
Anyone else experience similar symptoms? Intermittent problems can be so difficult to diagnose simply because they are intermittent.
   / Won't Start or Run Without Injector Pump Bleed #2
Is the flow from the tank to filter to the injection pump decent? It sounds like something is plugging the line.
Also, is the lift or primer pump pumping?
This weekend, I will check the feed from the tank to the fuel filter bowl to make sure there is no blockage there.
Not familiar with the "lift" or "primer pump" on this model (TC45DA), but I'll take a look at the service manual and do the necessary tests.
Thanks.
   / Won't Start or Run Without Injector Pump Bleed #4
also blow air back from the filter to the tank ... may have some crud in the tank that sloshes around till it finally clogs the fuel pickup ...
not sure , if that unit has a mechanical low pressure pump that feeds fuel to the injector pump ... it may be failing ....
   / Won't Start or Run Without Injector Pump Bleed #5
Thanks.
You started the thread with a fuel problem on a TN75V, now you're not sure about a lift pump on a TC45DA. Which one has a fuel problem?
2014 INTERNATIONAL PROSTAR (A58214)
2014 INTERNATIONAL...
2016 Chevrolet Tahoe SUV (A56859)
2016 Chevrolet...
2016 Ford Fusion Sedan (A55758)
2016 Ford Fusion...
2007 Hummer H3 4X4 SUV (A56859)
2007 Hummer H3 4X4...
2014 Ford Fusion AWD Sedan (A56859)
2014 Ford Fusion...
MASSAGE CHAIR (A58214)
