Wont Start Help
/ Wont Start Help #11
pull the injectors and crank it over.
Or glow plugs. This would be my next step. With the glow plugs or injectors out the engine should spin freely.
/ Wont Start Help
Ok i bench tested the starter and it spun, if i let,it spin for 10 seconds the starter is hot to the touch and the cables get red hot at the contacts ( using jumper cables) is this a bad starter?
/ Wont Start Help
Update. I just installed the starter and tried to start it using jumper cables from the battery directly to the starter. It spun 2 revolutions and then stopped and melted my cables. So the motor is not siezed as i can reach in and feel the flywheel moving when i pull on the belt. Im thinking this has to be a bad starter. it works fine on the bench but when its loaded with the motor than it just struggles for a second and heats way up. Do you agree? Bad Starter?
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A59823)
2018 GENIE...
2023 SNORKEL A46JRT ROUGH TERRAIN BOOM LIFT (A59823)
2023 SNORKEL...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
New/Unused 2025 CFG QK18R Mini Excavator (A61166)
New/Unused 2025...
2015 CATERPILLAR 930M LOADER (A58214)
2015 CATERPILLAR...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
