Bandit2026
Bronze Member
If my voltage regulator on my 8n sticks when I shut it down, would that cause it not to start??
Quick and dirty trick used to eliminate electrical is a whiff of starting fluid and then crank... if it starts 99% fuel issue.
If it makes no difference look to ignition... mostly points.
Sometimes I was told and old car ran fine when parked... then no spark when I tried to start.
Rubbing a business card between closed points often did the trick... the cardstock was rough enough to "Polish" the points.
