won't start after overturning my tractor
   / won't start after overturning my tractor #1
dwana7
I have an LS U5030c 2011 - I just turned it on its side and after getting her upright it won't start so is there a kill switch or a reset or anything? any info is appreciated
   / won't start after overturning my tractor #2
Yikes. Were you on it when it went over? If yes, you ok?
Sorry I don't have any suggestions regarding the starting problem.
   / won't start after overturning my tractor #3
If it ran for a bit before you shut it off, it's possible you got air in the fuel line. Have you bled the fuel lines?
That's a pretty good sized tractor to put on its side. We all want to know how it happened, how you (and the tractor fared), how you righted it, and for extra credit, what two words you said when it started to tip.
   / won't start after overturning my tractor #4
Does the engine turn over with the starter? If not it probably has oil in the cylinders.
Was brush hoggin on a field I do 4 times a year...the grandson had been on it and had it out of 4wheel drive and my dumbas.. didn't check it...she skidded like a sled on ice I am fine a small gash on top of my head is all= tractor side glass broke out and crumpled the top of the cab exhaust side...hit a few bumps n a hole n the tall weeds that tilted her or I may have been able to ride it to the flat bottom- set her up w/a d9 dozer n I said lots of pretty words but I think oh ****tttt was the first lol
   / won't start after overturning my tractor #6
Important clarification before any sound advice can be given......
Does the engine crank (turn with the starter) and not start, or does it not crank?
nope no crank going to pull injectors- thanks for idea
   / won't start after overturning my tractor #9
If it was on its side a "while" there could be enough oil in a cylinder to "lock" the engine.
My nephew locked a Duramax with just a little extra fuel (long story)
make sure the engine is not locked, some may call it hydrolocked.
2015 FONTAINE 53 DROP DECK (A55745)
2015 FONTAINE 53...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A55853)
2014 Glasstream...
2002 Bobcat 763 Compact Skid Steer (A56435)
2002 Bobcat 763...
UNUSED IRANCH IRET13 ELECTRIC TRICYCLE (A57192)
UNUSED IRANCH...
MERCURY VERADO ENGINES (A55758)
MERCURY VERADO...
KUBOTA ZG1235 ZERO TURN MOWER (A57192)
KUBOTA ZG1235 ZERO...
