I have an LS U5030c 2011 - I just turned it on its side and after getting her upright it won't start so is there a kill switch or a reset or anything? any info is appreciated
If it ran for a bit before you shut it off, it's possible you got air in the fuel line. Have you bled the fuel lines?
That's a pretty good sized tractor to put on its side. We all want to know how it happened, how you (and the tractor fared), how you righted it, and for extra credit, what two words you said when it started to tip.
Important clarification before any sound advice can be given......
Does the engine crank (turn with the starter) and not start, or does it not crank?
Okay, you are on the right path then.nope no crank going to pull injectors- thanks for idea
