Oil & Fuel Won't start after fuel filter change
   / Won't start after fuel filter change #1
CaptainJDS
East Texas
Looking to make a purchase soon
O.K. bought a grey market MF1228 (Hinomoto E279) and changed all the fluids including fuel filter. Cranked it right up after and it ran for a minute and slowly died. She'll turn over and over, but won't fire off. I'm sure diesel is not making it to the motor and the fuel filter is full of fuel.
Any suggestions!
Thanks,
J.D.
   / Won't start after fuel filter change #2
You could try cracking the fuel line loose at the injector pump, and turn the key to the on position. When fuel comes out steady, tighten the line, and try to start the engine.
   / Won't start after fuel filter change #3
G'day as Ray said crack he inj line at the inj but crank it over til you get fuel at the inj then nip up and should start. You didn't turn fuel off when you changed filter did you????????????
Jon
Shutting off the fuel before changing the filter was discovered after the fact! Lesson learned! One of thousands ahead of me. My oldest son was on the project this morning. Cracked the lines on the cylinders, cranked the beast until he got fuel and got her running. Now if the auto pilot would engage to mow the pasture, we'd have it made!
Thanks and G-d bless,
J.D.
1998 JOHN DEERE 643G FELLER BUNCHER (A51242)
1998 JOHN DEERE...
2020 Ford F-150 Crew Cab Pickup Truck (A50323)
2020 Ford F-150...
2014 Mack CXU613 T/A Day Cab Truck Tractor (A50323)
2014 Mack CXU613...
MILITARY MI-T-M CLEANER / STEAM PRESSURE WASHER (A51244)
MILITARY MI-T-M...
2002 Semi Deck Over Trailer (A50514)
2002 Semi Deck...
EZGO GOLF CART (A50323)
EZGO GOLF CART...
