Oil & Fuel Won't start after fuel filter change
   / Won't start after fuel filter change #1
CaptainJDS
East Texas
Looking to make a purchase soon
O.K. bought a grey market MF1228 (Hinomoto E279) and changed all the fluids including fuel filter. Cranked it right up after and it ran for a minute and slowly died. She'll turn over and over, but won't fire off. I'm sure diesel is not making it to the motor and the fuel filter is full of fuel.
Any suggestions!
Thanks,
J.D.
   / Won't start after fuel filter change #2
You could try cracking the fuel line loose at the injector pump, and turn the key to the on position. When fuel comes out steady, tighten the line, and try to start the engine.
   / Won't start after fuel filter change #3
G'day as Ray said crack he inj line at the inj but crank it over til you get fuel at the inj then nip up and should start. You didn't turn fuel off when you changed filter did you????????????
Jon
Shutting off the fuel before changing the filter was discovered after the fact! Lesson learned! One of thousands ahead of me. My oldest son was on the project this morning. Cracked the lines on the cylinders, cranked the beast until he got fuel and got her running. Now if the auto pilot would engage to mow the pasture, we'd have it made!
Thanks and G-d bless,
J.D.
2014 Ford Explorer XLT SUV (A50324)
2014 Ford Explorer...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
2018 Nissan Versa Sedan (A50324)
2018 Nissan Versa...
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2012 MACK CHU613 DAY CAB FLAT TOP ROAD TRACTOR (A51243)
2012 MACK CHU613...
