wont run with air filter installed
   / wont run with air filter installed #1
old sears
maine
gilson sears speedex craftsman
i have a 1984 briggs 16 hp. horizontal opposed twin runs great but if i put air filter on or even put my hand near carb starts to die why any ideas would be greatful for any help
   / wont run with air filter installed #2
Consider adjusting, cleaning or rebuilding the carb. Sounds like it is running too rich and any reduction of air flow is causing flooding.
Assuming you have fresh fuel.
changed oil when i had one beer to many
drained oil again this time did not over fill and it looks like shes coming out of it thanks for the info
   / wont run with air filter installed #5
I am surprised that overfilling oil would allow it to run with or without air filter. I suppose that if too much oil it would foam up and backup into carb and even a little restriction from the filter would starve it for air.
By the way, too much oil is about the worst thing you can do to an engine.
i rebuilt the carb the day after the oil changed the oil started right up ran great for 2 or three minutes then the oil was every where lesson learned dont drink when working on any of my tractors thanks for the help
thanks
to all that toke time to try and help me with my stalling out problem thanks and happy holidays to you thanks again old sears
   / wont run with air filter installed #9
Words of wisdom.
2007 FORD F-250XL SUPER DUTY TRUCK (A54756)
2007 FORD F-250XL...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
2014 Ford F-150 Ext. Cab Pickup Truck (A55788)
2014 Ford F-150...
2016 Sakai SV540 Padfoot Compact Roller (A54865)
2016 Sakai SV540...
2014 Ford F-150 Ext. Cab 4x4 Pickup Truck (A55788)
2014 Ford F-150...
