Wont run under load after replacing drive belt
   / Wont run under load after replacing drive belt #1
rickh281
miami
Club Cadet LT1045
I own a Cub Cadet LT1045, replaced the drive belt and it ran under load for approximately 1 minute. I got it back started by feathering the choke, ran at low idle for several minutes, increased rpm's to full, still ok, engaged forward gear and it stalled after several seconds. Fuel is good, oil the same. I did have it standing on its tail as I did the repairs. I've read other threads, don't know if I messed up the timing or how that could occur. Just pulled off the clutch assembly, bent the keeper tabs open to install the belt, then put the clutch back on.
Thank you for your help.
Rick
   / Wont run under load after replacing drive belt #2
Good morning, try jacking up the rear wheels just off the ground and after the engine has warmed up try some back and forth peddle action. That might clear up any air bubbles in the system...if that is the problem.
Thank you....pulled the carb, cleaned and did what you suggested. Tractor is running without stalling.
PENDING SELLER CONFIRMATION  READ BEFORE BIDDING (A56435)
PENDING SELLER...
2002 Bobcat 763 High Flow Compact Wheel Loader Skid Steer (A55851)
2002 Bobcat 763...
UNUSED JCT DB500 DUSTLESS BLASTER (A57193)
UNUSED JCT DB500...
Magnolia Trailer with Adams 25 Ton Fertilizer Tender (A57024)
Magnolia Trailer...
UNUSED CAPTOK CK-P45 MINI HYD BREAKER HAMMER (A57193)
UNUSED CAPTOK...
RV Hitch (A50121)
RV Hitch (A50121)
