wont go
   / wont go #1
lundblad
john deere 4200
say Ive got a john deere 4200 that wont roll seems as though the brakes are stuck on can anyone advise thanks much
   / wont go #2
First, welcome to TBN. When was the last time the tractor moved? Is it possible that it's in gear, hence the transmission is holding it? What have you done to remedy?
Mike
   / wont go #4
Most likely the clutch is stuck. Ken Sweet
I agree. I was advised by the dealer service dept., when my tractor was delivered to block the clutch petal down anytime I wasn't going to use the tractor in the next day or two.He said most times the only fix is to split the tractor.
amaxwell
   / wont go #5
Be sure to look for the simple fixes first like the range selector not being between ranges or in neutral. I care not to discuss how I know about this any further. :D
   / wont go #6
If the HST is "in gear", then the tractor won't role due to the hydro fluid, t'ain't like an automobile tranny with a torque converter.....
Most likely it is the brake cams being stuck in the on position if the gearbox (or hydro) is in neutral. The springs that are supposed to pull them off just don't seem strong enough once corrosion sets into the aluminium housing with the steel brake cam shafts.
Crawl under and give them both a tap with a hammer to release....
   / wont go #7
I'm curious about that comment.
When I first got my 4400 (sync-reverser), I asked (on TBN) about where to clamp down the clutch pedal (the ol' 790 had a tab you could use to clamp down).
Most responses were "it's a wet disk and not necessary".
So, this should apply to lundblad's 4200 (if his machine is gear).
But, of course, tha main question is, do you need to block a wet disk clutch?
RIGID 141 THREADER (A53843)
RIGID 141 THREADER...
2017 PETERBILT 579 (A53843)
2017 PETERBILT 579...
2007 JOHN DEERE 7630 TRACTOR (A53843)
2007 JOHN DEERE...
Honda EU3000is Gasoline Companion Inverter Generators (A54811)
Honda EU3000is...
2016 Ford F-450 12FT Flatbed Truck (A51692)
2016 Ford F-450...
