wondering if any LED light conversions will bolt right inplace of factory Kioti light
   / wondering if any LED light conversions will bolt right inplace of factory Kioti light #1
grsthegreat
Super Star Member
north idaho
Kioti DK45SE hst cab
getting ready for winter, and was wondering if anyone has had success with replacing existing kioti cab lights (factory) with decent LED replacements. im ok with the factory lights, but was just pondering future replacements. dont want to have to modify factory light mounts.
any suggestions or actual results.
   / wondering if any LED light conversions will bolt right inplace of factory Kioti light #2
Wondering something similar, though I'm fine with just bolting them to the ROP. Just need something that is brighter than the dim orange glow of the factory lights.
   / wondering if any LED light conversions will bolt right inplace of factory Kioti light #3
Yes, I've replaced the Kioti factory lights with 36 watt Cree LED's. Night and Day difference (pun intended). I replaced the rear lights with the same 36 watt LED's. The LED's actually draw less current then the factory halogen lights. Just remove the Cab lid and cut into the factory wiring system. I'm using LED flood lights, I started with 18 watt LED's on the rear..but it just wasn't enough. The 36 watt are VERY Bright!!! You can find tons of types and styles on E bay or Amazon for a decent price. I'm about $70.00 a pair delivered to my door.
   / wondering if any LED light conversions will bolt right inplace of factory Kioti light #4
Whalen makes a 6 head led light called the nano. I just replaced the factory lights on my nx6010 kioti. They are unbelievable. I can almost light up a football field.these lights are 1,800 lumend each.
i found some 36 watt LED's on ebay. got 4 of them for $140.00 delivered . i thought $35 per light was doable. Took 2 hours to install. they were direct replacement. no new brackets needed.
im a convert.....used to think factory were enough. but these are very very bright.
light remounted.jpgfront lights installed.jpgexisting bracket.jpgnew light mounted.jpgrear light feed.jpgrear light installed.jpgrear light.jpgfront light installed.jpg
before install. looked brighter in shop than picture makes it out to be. headlight and overhead light on. original lighting.jpg
after install . new LED lighting . forgot to turn on headlights also like original pic..oh well. led lighting.jpg
   / wondering if any LED light conversions will bolt right inplace of factory Kioti light #6
LED's are nice. I put grote Trilliant's on my tractor.
YOKOHAMA - GALAXY 16.9-24 DIAMOND BUTTON TIRES (A52748)
YOKOHAMA - GALAXY...
43002 (A51691)
43002 (A51691)
2020 KENWORTH W900L DAY CAB (A52472)
2020 KENWORTH...
2013 Ford F-650 Truck (A51692)
2013 Ford F-650...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
2015 ISUZU NPR 16FT BOX TRUCK (A52576)
2015 ISUZU NPR...
