Oil & Fuel Wix Hyd and Fuel filters for CK4010 HST
   / Wix Hyd and Fuel filters for CK4010 HST #21
I use the Donaldson phone number and call them up.
in my case the part number of the Donaldson filter itself is still new so I recorded it.
If you have that number it will help, or call them up. They have been pretty helpful thus far for me.
Ok, I will try that.
   / Wix Hyd and Fuel filters for CK4010 HST #23
I'm going to cut the baldwin filter open when i change the oil on the new machine in a couple of weeks to see what's different inside from the kubota filter
The video I watch about why one should never buy a fram filter was very revealing.
Number of pleats, how the element is secured, the drain back valve and thickness of material, etc., was pretty surprised.
So when you do this keep us posted, should be informative for us.
Depends on the year model. My CK4010 (2016) did not have an inner filter but did notice the 2017/18s do.
Dealer should help clear that one up.
Ok, maybe that's it.... BTW... So do you own both an NX4510HST and a CK4010?
   / Wix Hyd and Fuel filters for CK4010 HST #26
See if this helps:
4 E7230-11081 Air cleaner 1 P822768 FP G068506 Donaldson
I made this excel spread sheet and copied all the filters.
If your interested PM me and if I'm allowed to send attachments I'll send you the maintenance template.
I know back it the 80's if you put a Fram on a Chrysler or Plymouth 4/6 cyl they would knock like crazy... I witnessed that for myself, always heard not to use them. I use all Mobil 1 filters on all of my vehicles and bikes.
See if this helps:
Great!! just PM'd you...
   / Wix Hyd and Fuel filters for CK4010 HST #29
Sadly I do miss the Ck, traded it for the NX.
Ten hours later the NX plows those huisache root with ease! If it were not for the 5 acres of needing plowing I would still have the CK. It a good machine and did everything I needed done, until I tried to max its limits...ha! All four wheels just spun....ha...
Cool... Well I do know I have pushed mine to its limits as well... using the grapple and either a box blade or bush hog on the back... lots of spinning... however, I put the backhoe of it a few days ago and was picking up probably 1,000 pound rocks in soft dirt and no problem!
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2013 Peterbilt 367 20Yd Ox Bodies Tri-Axle Dump Truck (A56858)
2013 Peterbilt 367...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
72" ROCK BUCKET (A52706)
72" ROCK BUCKET...
2023 PITTS LB35-33CS LOWBOY TRAILER (A58018)
2023 PITTS...
