Wisconsin TRA-10D Bearing Grouling
   / Wisconsin TRA-10D Bearing Grouling #1
Bolens 1050
John Deere Model A 1952, Bolens 1050, Gravley model "L", Reel Mowers
I just got my engine back from the machine shop. I got it bored, the crank machined, the endplay set, and the valves ground. I only have one problem, I put my crank in and put the crankcase cover back on and tured my crank. It makes a grouling clicing noise. Sould I replace the bearing or leave it be. My gut intinct says replace it, but im not sure on pricing. What should I do ?:confused:
   / Wisconsin TRA-10D Bearing Grouling #2
I don't know anything about your machine, but a growling, clicking noise would tell me I've got to take it apart again, replace bad bearing, or whatever is making that noise.
   / Wisconsin TRA-10D Bearing Grouling #3
The bearing on the crank is oil lubricated and right now it is dry so it will make that click and growl until you get oil in the crankcase
Freightliner Tender Truck (A53473)
Freightliner...
2005 Frieghtliner 18' Box Truck (A52377)
2005 Frieghtliner...
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A53426)
2007 POWERSCREEN...
2015 JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
2015 JCB 525-60T4...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A53473)
Kubota BX2680...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
