Wisconsin TRA-10D Bearing Grouling
   / Wisconsin TRA-10D Bearing Grouling #1
Bolens 1050
John Deere Model A 1952, Bolens 1050, Gravley model "L", Reel Mowers
I just got my engine back from the machine shop. I got it bored, the crank machined, the endplay set, and the valves ground. I only have one problem, I put my crank in and put the crankcase cover back on and tured my crank. It makes a grouling clicing noise. Sould I replace the bearing or leave it be. My gut intinct says replace it, but im not sure on pricing. What should I do ?:confused:
   / Wisconsin TRA-10D Bearing Grouling #2
I don't know anything about your machine, but a growling, clicking noise would tell me I've got to take it apart again, replace bad bearing, or whatever is making that noise.
   / Wisconsin TRA-10D Bearing Grouling #3
The bearing on the crank is oil lubricated and right now it is dry so it will make that click and growl until you get oil in the crankcase
2012 Ford F250 XLT, Super Cab Long Bed (A52384)
2012 Ford F250...
2006 Wabash National 28ft Dry Van Trailer (A51692)
2006 Wabash...
2025 K732 UNUSED Flower Bed (A53117)
2025 K732 UNUSED...
CFG Industrial SAII100 (A50123)
CFG Industrial...
2019 MACK PINNACLE (A53843)
2019 MACK PINNACLE...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
