wisconsin engine question
/ wisconsin engine question #1
mostlyred
i just got a model tfd 3 1/4x 3 1/4...can anyone tell what the rated horsepower is and rpm?what is the procedure for setting the timing? when i was checking the firing it fires both plugs simutaneous.:confused:so i am assuming doesnt matter which wire goes to dedicated plug ,,wiring order ,or am i missing something here...mag was loose when i got it and wants to kick back any help would be appreciated thanks
/ wisconsin engine question #2
TFD? I know of the THD and TJD. I have a THD 3 1/4" x 3 1/4" on an old welder and it's allegedly 15-18.
The THD fires both cylinders simultaneously. A friend of mine calls them "thumpers" but they're not that bad.
As for service information, I found everything I needed in a small air cooled engine service manual at the library. I'm afraid to say that I don't have any numbers for you because when I need info, I just go to the library.
If it's a crank start engine, then make sure that the timing is properly set. One of my uncles was badly hurt by a starting handle when an engine he was starting backfired. I realize there was a technique issue there as well, but just the same...
2002 Ford F-550 Crew Cab Landscape Dump Truck (A56858)
2002 Ford F-550...
(296) 1"X6"X6' TONGUE & GROOVE (A62131)
(296) 1"X6"X6'...
2016 Etnyre Falcon Live Bottom Trailer (A62613)
2016 Etnyre Falcon...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
4ft Mini Skid Quick Attach Rotary Cutter (A63118)
4ft Mini Skid...
300 GALLON FUEL TANK (A62131)
300 GALLON FUEL...
