wisconsin engine question
/ wisconsin engine question #1
mostlyred
i just got a model tfd 3 1/4x 3 1/4...can anyone tell what the rated horsepower is and rpm?what is the procedure for setting the timing? when i was checking the firing it fires both plugs simutaneous.:confused:so i am assuming doesnt matter which wire goes to dedicated plug ,,wiring order ,or am i missing something here...mag was loose when i got it and wants to kick back any help would be appreciated thanks
/ wisconsin engine question #2
TFD? I know of the THD and TJD. I have a THD 3 1/4" x 3 1/4" on an old welder and it's allegedly 15-18.
The THD fires both cylinders simultaneously. A friend of mine calls them "thumpers" but they're not that bad.
As for service information, I found everything I needed in a small air cooled engine service manual at the library. I'm afraid to say that I don't have any numbers for you because when I need info, I just go to the library.
If it's a crank start engine, then make sure that the timing is properly set. One of my uncles was badly hurt by a starting handle when an engine he was starting backfired. I realize there was a technique issue there as well, but just the same...
Case SV280B (A60462)
36" X 72" CONCESSION DOOR (A62131)
36" X 72"...
UNUSED KJ K2010 HD CHICKEN COOP (A62131)
UNUSED KJ K2010 HD...
(APPROX.20) UNUSED RAYSKY GROUND PROTECTION MATS (A62131)
(APPROX.20) UNUSED...
Deutz Diesel Engine (A61568)
Deutz Diesel...
Hypac C852B Packer (A61166)
Hypac C852B Packer...
