wirirng problem
/ wirirng problem #1
rickc2002
south hill,va
Farm Pro 4/wd 2430 diesel
I have new wiring harness for my Farm Pro 2430 tractor, what I don't have is
color coder wiring diagram. Any Help?
/ wirirng problem #2
I don't understand your question. Wiring systems are made to be nearly idiot proof in that connectors will only plug into the correct mate .
Where did you buy the harness and why?
Sometimes Owner's manuals will have wiring diagrams in the back pages.
You can buy wiring diagrams on line.
Dave M7040
/ wirirng problem
Dave M7040
The wiring harness isn't the exact replacement, more wires and connectors. My tractor is older model
that harness is no longer available. That's why I wanted color coded diagram to match up wires.
This is a made in China Farm Pro so not that common. Looks like I will have to splice wires where connectors don't match
Bought from Asian Tractors, have asked for coded diagram but no response yet. Wires are old and brittle.
/ wirirng problem #4
I would be asking the harness supplier to provide matching connectors for those in the new harness.
In that way should you want to remove say the alternator, you are unplugging a new plug a few inches away from the old original brittle connector on the alternator.
Do you have a wiring diagram for the tractor the new harness was intended for?
Is your tractor sold under other names?
Often there are universal standards for labeling switches and wires so a #17 terminal on a key switch means the same thing as the #17 terminal on a different brand of tractor
These links are just intended to get you to consider approaching your wiring upgrade from a different perspective.
The one standard I know is DIN 72552 which is European but undoubtedly the Chinese either have their own standards or using DIN perhaps
DIN 72552 - Wikipedia
http://www.e38.org/understanding euro wiring diagrams.pdf
http://www.bosch-classic.com/media/...switches/downloads_3/klemmenbezeichnungen.pdf
Wire and wire codes, metric and American, for vehicles, particularly BMW motorcycles, reading schematics
I have used this web site to download a WSM for a tractor trying to help someone. The quality was very good. It did not have the latest details but in your case it might not matter.
Service Manual Vault Contact Information
I don't see your tractor listed but as I asked earlier, your tractor may also be sold under a different name which might be on the web site.
Could you take a picture of the back side of your key switch that shows the # for each terminal. It might be a great clue as to what standard the Chinese manufacturers are using.
Dave M7040
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
2016 Volvo Semi Truck (A66285)
2016 Volvo Semi...
2026 SDlanch SDLE20 (A64127)
2026 SDlanch...
2000 Pro Stock Utility Trailer (A66285)
2000 Pro Stock...
Used Landpride GR1525 Stump Grinder
Used Landpride...
New 20' Container  (A62679)
New 20' Container...
