wiring up a winch
   / wiring up a winch #1
junglejim
Bedford Pa
Ingersoll 4020
Got a electric winch and want to wire it to tractor which is a positive ground. Do I hook the positive of the winch to the negative battery terminal? Thanks
   / wiring up a winch #2
I don't have much experience with positive ground systems, but if you have a multimeter check the voltage first and see where you're getting positive voltage.
   / wiring up a winch #4
Positive should always connect to positive. In your case either to the positive terminal of the battery or to the metal frame of the tractor. What you'll want to do is put any relays and/ or fuses on the negative wire near the battery.
   / wiring up a winch #5
A winch motor will turn in both directions. When you swirch polarity it turns in yhe opposite direction.
To demonstrate this to yourself, hook up a set of jumper cables to the winch note how it turns and then switch the cables and you will see it reverse.
That's thr reason winches have either relays or solenoids. They allow you to use a small switch to energize the solenoids differently so thst it changes the polarity.
In otherwords it shouldn't matter about positive ground. It only changes the in out.
   / wiring up a winch #6
I need to stand corrected. My winch motor is permanent magnet and therefore it switches direction with polarity change. Not all winch motors are permanent magnet and therefore all don't behave the way I stated. Thanks to K7LN for his help via PM's to help me understand.
To the OP, let us know how you work it out. I'm sure it will be helpful to a number of people with positive ground tractors.
   / wiring up a winch
:thumbsup: Everything is working fine with winch no smoke . The charging system is to small to keep up with the electric draw of the winch . Good reason to take a rest . Thanks
   / wiring up a winch #8
So how did you hook it up?
   / wiring up a winch #9
Your electric winch -depending upon size - will draw anywhere from 500 - 800 amps at full pull. There are few, if any, charging systems on any type vehicle that can keep up with this draw on a battery. A really strong system will allow 10%-15% operational time. That means 10% of the time pulling/running and 90% of the time recharging the battery. Many folks run double batteries to increase the pull/run time.
Be very careful with a winch system. It is quite easy to overuse and boil off a battery. The discharge/recharge cycles are so heavy the fluid in the battery becomes hot and will actually boil off. I have seen a few time where a battery will get so hot it explodes.
   / wiring up a winch
Put pos to pos and neg to neg The book said if the switch worked backwards to hook it to battery the other way. If all else fails you can read the book .
JOHN DEERE RC7 R LOT NUMBER 224 (A53084)
JOHN DEERE RC7 R...
Massey Ferguson 231 Tractor with Loader (A51573)
Massey Ferguson...
2022 CATERPILLAR 259D3 SKID STEER (A51246)
2022 CATERPILLAR...
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A52377)
2014 Ford F-450...
